trans gear ratios
Old May 26, 2003 | 12:09 PM
speedworks's Avatar
Default trans gear ratios
does anyone remember the website that has the gear ratios for the h series transmissions.
Old May 26, 2003 | 05:00 PM
DLB1994's Avatar
Default Re: trans gear ratios (speedworks)
93-96 H22A1 M2F4
1st-3.307
2nd-1.950
3rd-1.360
4th-1.071
5th-.870
R-3.0
F-4.266
93-96 H23A1 M2S4
1st-3.307
2nd-1.857
3rd-1.320
4th-1.034
5th-.812
R-3.0
F-4.266
93-96 F22A1 ?
1st-3.307
2nd-1.809
3rd-1.230
4th-.903
5th-.705
R-3.0
F-4.062
Old May 26, 2003 | 05:20 PM
speedworks's Avatar
Default Re: trans gear ratios (DLB1994)
the reason i ask is that i am trying to figure out what trans will help me to stay in fourth gear through the quarter mile. the h22 causes me to have to go to fifth around the 1000 foot mark. should i put in the h23 trans or just change the final drive from the f22 into the h22 trans
Old May 26, 2003 | 09:06 PM
DLB1994's Avatar
what size slicks you running
Old May 26, 2003 | 10:52 PM
pissedoffsol's Avatar
hondaswap.com y0!
here:
http://www.hondaswap.com/files/netmph.xls
Old May 26, 2003 | 10:57 PM
VaporTrail's Avatar
New User
go with a bigger slick
Old May 27, 2003 | 03:11 AM
speedworks's Avatar
Default Re: trans gear ratios (VaporTrail)
24.5/8/13 slicks. if i go with bigger slicks that means new bogarts/new tires/one peice front end. i would rather change the trans since i have the h23 and f22 already.
Old May 27, 2003 | 04:16 PM
speedworks's Avatar
anyone with some other insight on this subject
Old May 31, 2003 | 07:31 PM
speedworks's Avatar
update on gear ratios. put in the h23 trans. took it to the track today. new trans kept me from having to go into fifth gear, but barely. it also cured alot of the wheel spin when going into second gear.et's and mile per hour stayed the same. i might try putting the mainshaft and ring gear from the single cam prelude trans in the h22 trans which will change the final drive ratio and keep the close ratio gears of the h22.
accord2civic2prelude
Nov 24, 2009 02:59 AM
NirVTEC
May 1, 2005 11:12 PM
