drivable? with no piping?
Old May 25, 2003 | 08:35 AM
r7's Avatar
r7
Default drivable? with no piping?
can i drive?
no piping, just filter on turbo inlet, outlet to nothing
and filter on throttle body
oil send/return hooked up
drivable? or?
Old May 25, 2003 | 08:54 AM
This One's Avatar
Default Re: drivable? with no piping? (r7)
you can drive it......
it wont hurt anything
Old May 25, 2003 | 09:00 AM
VaporTrail's Avatar
New User
Default Re: drivable? with no piping? (tHE oNE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tHE oNE &raquo;</TD></TR><TR><TD CLASS="quote">you can drive it......
it wont hurt anything</TD></TR></TABLE>
wrong. You can EASILY overspin the turbo.
Old May 25, 2003 | 09:13 AM
93LSivic's Avatar
Default Re: drivable? with no piping? (VaporTrail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail &raquo;</TD></TR><TR><TD CLASS="quote">
wrong. You can EASILY overspin the turbo.</TD></TR></TABLE>
True dat. Dont listen to uneducated people like the one above.
You can burn up the bearings in the turbo by overspinning it.
Old May 25, 2003 | 09:14 AM
This One's Avatar
Default Re: drivable? with no piping? (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">
You can burn up the bearings in the turbo by overspinning it.</TD></TR></TABLE>
dont get on it?
i dont understand that....... sorry
Old May 25, 2003 | 09:25 AM
DIRep972's Avatar
Smarter than you
w/ out piping the turbo will just spool up to infinity. Nothing to stop it. If you drive w/ out piping for any extended period of time you can put money on it that you will damage your turbo.
Old May 25, 2003 | 09:28 AM
This One's Avatar
Default Re: drivable? with no piping? (DIRep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep &raquo;</TD></TR><TR><TD CLASS="quote">w/ out piping the turbo will just spool up to infinity. Nothing to stop it. If you drive w/ out piping for any extended period of time you can put money on it that you will damage your turbo.</TD></TR></TABLE>
Make sense.
i been in numerous situations where I drove my car numerous times with no piping, on diff setups.
**** was fine, but then agian i wasn't out racing people with it.
there is no way the turbo is going to spool itself if your not giving it throttle to spool it.
Old May 25, 2003 | 09:31 AM
pub's Avatar
pub
Yeah, listen to these guys. I was in the same situation as you. If it's not in a closed loop, you will overspin your turbo greatly.
There's a fix to this problem however. If you have a tial wastegate, take the fire ring and flip it backwards. With the smaller diameter facing the manifold/elbow. This will keep your wastegate open and have alot of the exhaust gases going out the dumptube. There shouldn't be enough gas to get the turbo to spin into boost. I only did this to drive from the exhaust shop back home (5 miles) It was damn noisy but it got the job done. I wouldn't suggest doing this, but if it's your only option - it's a good way to keep your turbo safe. Just be sure it doesn't spool.
Modified by pub at 1:47 PM 5/25/2003
Old May 25, 2003 | 10:00 AM
boosted92's Avatar
Default Re: drivable? with no piping? (pub)
Another solution isto make yourself a really really ghetto-*** exhaust dump. We had the same problem on my buds civic when we were taking it for the turbo back exhaust and intake piping, so we unbolted the turbo from the manifold, duct taped it to the head (so we wouldn't be leaking oil from the feed and return lines) and welded a flange onto some 2.25" piping with a stock muffler from a mustang To show you what I mean, here is my all-star drawing. Notice the elite front mount effect
Old May 25, 2003 | 10:18 AM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r7 &raquo;</TD></TR><TR><TD CLASS="quote">can i drive?
drivable? or?</TD></TR></TABLE>
Like mentioned above you acn drve it, just don't get on it... I had to drive my car with no piping to a shop to get it made... I had a half cut downpipe and no charge pipes whatsoever... Just take it slow and you should be fine... ...
Old May 25, 2003 | 10:22 AM
This One's Avatar
Default Re: drivable? with no piping? (4U2NV)
your turbo probaly doesn't start spooling until 3 or so anyways. and thats with throttle!
dont get on it and you will be fine
Old May 25, 2003 | 04:31 PM
r7's Avatar
r7
thanks for the replys.
Old May 25, 2003 | 06:58 PM
TurBoXBirD16's Avatar
How about if the piping is connected to the intercooler
than not connectted to the throtle body??
same thing??
thegeezerkid
Jun 14, 2008 10:56 PM
G0TB00ST
Apr 2, 2007 09:32 PM
Street2uned ef
Sep 4, 2006 07:12 PM
RemerLex11
Dec 26, 2005 11:32 PM
effinnwackk
37
Apr 13, 2005 11:43 PM
