Home Made Catchcan
Old May 26, 2003 | 02:05 PM
TurboDANDEE's Avatar
Default Home Made Catchcan
Well, im broke so i decided to make my own catchcan while keeping the OEM look. I used the emission filter can on the firewall since i cant pass emissions anyways. First thing i did was cut it open to remove all the charcoal inside and cleaned it up, i found out that it was already baffled so it was a good thing. Drilled 2 holes for the fittings, added a filter on the baffled part, plugged up one vacuum port and glued the bottom back on. I got rid of my PCV system and made it into open loop, just had the black box behind the block, valve cover breather and gas tank ventilation all routed back into the catchcan. well i hope my pics work, enjoy!
EDIT: SCROLL DOWN FOR PICS
Modified by TurboDANDEE at 6:10 PM 5/26/2003
Old May 26, 2003 | 02:11 PM
Poop111444's Avatar
Default Re: Home Made Catchcan (TurboDANDEE)
Nice! I like. Are there any downsides to doing this mod such as gas mileage or whatnot? Im in MI, no emission testing or anything
Old May 26, 2003 | 02:13 PM
631 Teggy's Avatar
Default Re: Home Made Catchcan (si_mekanik)
i hate imagestation.. .They don't show up unless you log in I believe...
Old May 26, 2003 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_mekanik &raquo;</TD></TR><TR><TD CLASS="quote">Nice! I like. Are there any downsides to doing this mod such as gas mileage or whatnot? Im in MI, no emission testing or anything</TD></TR></TABLE>
Gas mileage should be better since the oil vapors arent being burned anymore. I dont see any performance downside to this mod at all, unless someone can point it out for me?
Default Re: Home Made Catchcan (631 Teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">i hate imagestation.. .They don't show up unless you log in I believe...</TD></TR></TABLE>
sorry man, thats all i can go through... unless someone would host it for me
Old May 26, 2003 | 02:25 PM
Mr. Softee's Avatar
host @ we-todd it
Old May 26, 2003 | 02:41 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDANDEE &raquo;</TD></TR><TR><TD CLASS="quote">
Jordo fixed it 0
What part is that? the actual can
Old May 26, 2003 | 03:06 PM
Default Re: Home Made Catchcan (Jordo)
Thanx for hosting
The can is the emission filter on the firewall... all honda's have em, just look under ur battery and its that black can.
Old May 26, 2003 | 03:15 PM
blmracing's Avatar
that's just gangsta
Old May 26, 2003 | 03:59 PM
DragEG6 FI's Avatar
Default Re: Home Made Catchcan (onesikvtec)
where can I get that breather filter at?
Old May 26, 2003 | 05:42 PM
SEFIxCivic's Avatar
kool idea dandee
Old May 26, 2003 | 05:47 PM
93LSivic's Avatar
Default Re: (GSRslowandswap)
Im about to do this on my car. Im going to be using the A/C dryer--i looked inside one of the bolt holes the other day and its baffled at the bottom.
TO properly do this you should make it closed loop. Simply done, just attach a line from where your breather filter is going over to the intake side of the turbo---the only place where constant vaccum will be one a turbo car.
This is a great mod, I cant wait to start on it.
Also another idea. Goto Home Depot and get a petcock and tap it into the bottom so that you can drain that sucker!
Old May 26, 2003 | 05:56 PM
speedworks's Avatar
Default Re: (93LSivic)
be careful using an a/c dryer,they have a pouch in them that is filled with a substance that resembles sand. not good for a cooling system.
Old May 26, 2003 | 05:57 PM
Danger's Avatar
nice DIY . im going to have to try that after i ref my ITR motor
Old May 26, 2003 | 05:59 PM
Default Re: Home Made Catchcan (Boost`n.eg^b18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost`n.eg^b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">where can I get that breather filter at?</TD></TR></TABLE>
got it from Autozone for $8.00
Old May 26, 2003 | 06:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRslowandswap &raquo;</TD></TR><TR><TD CLASS="quote">did you remove all the carbon parts inside?
of did you just put on the barb fittings and remove the evap?</TD></TR></TABLE>
i cut open the bottom, removed all the charcoal particles inside, cleaned it up and sealed it back up.
Old May 26, 2003 | 06:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Also another idea. Goto Home Depot and get a petcock and tap it into the bottom so that you can drain that sucker!</TD></TR></TABLE>
Oh ya, i forgot to mention that i tapped the bottom and put a 1/8th plug on it.
Old May 26, 2003 | 06:03 PM
Default Re: Home Made Catchcan (SEFI8LOxCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEFI8LOxCivic &raquo;</TD></TR><TR><TD CLASS="quote">kool idea dandee</TD></TR></TABLE>
thanx man, i tend to do creative stuff when im broke and cant afford nice things
Old May 26, 2003 | 06:18 PM
Joseph Davis's Avatar
Very creative.
Old May 26, 2003 | 06:43 PM
st00pid's Avatar
lol.. Looks good dandee.. good thinking!
Old May 26, 2003 | 08:11 PM
madman604's Avatar
most of the ones i've seen were made of ABS piping with end caps. personally, i dont wanna chop up any emission equip.
Old May 26, 2003 | 08:20 PM
Hispeed's Avatar
Neeto! But just one question do you have a drain plug on the bottom to drain it if it gets full?
Old May 26, 2003 | 08:29 PM
Pritos's Avatar
New User
Default Re: Home Made Catchcan (GSRev)
dang I like that! I'd just buy a 2nd canister and mount it next to it. thats clean.. me likes. me likes.
Old May 26, 2003 | 08:36 PM
hybrid_KJ's Avatar
Default Re: Home Made Catchcan (Pritos)
I made one using the a/c dryer. I cut it open and removed the sand bag, inserted a bunch steel wool for the oil to cling to. Tapped a bolt into the bottom for periodic draing and welded the sucker back together. Looks pretty cool since it is made of aluminum.
Old May 26, 2003 | 09:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRev &raquo;</TD></TR><TR><TD CLASS="quote">Neeto! But just one question do you have a drain plug on the bottom to drain it if it gets full? </TD></TR></TABLE>
Yes sir, i tapped a plug on a bottom so i can unscrew it when its full.
