cylinder flooding with gas
Old May 26, 2003 | 08:48 PM
jazz215's Avatar
Default cylinder flooding with gas
Hi guys,
d16z6, rebuilt engine, new distrib, plugs,wires, belts.
#2 injector is flooding the cylinder, I had replaced injector, harness, ecu. i had just cut the harness and hooked it directy to the ecu. and still its dumping fuel into the cylinder!!??!! i ran out of ideas of what it could be, could it be the fuel injection relay? (but all the other injectors are fine) ill even give someone money to help me fix this one....
Old May 26, 2003 | 11:40 PM
MiraiZ's Avatar
Default Re: cylinder flooding with gas (jazz215)
try swapping the injectors around....
Old May 27, 2003 | 09:10 AM
jazz215's Avatar
Default Re: cylinder flooding with gas (MiraiZ)
ive actually swapped them out with another working set, still the same problem. sigh... how much to auto electricians cost per/hour?
Old May 27, 2003 | 09:41 AM
Joseph Davis's Avatar
If you've already verified the #2 injector wiring isn't shorted to ground... try a different ECU.
Old May 27, 2003 | 09:48 AM
jazz215's Avatar
Default Re: cylinder flooding with gas (J. Davis)
.. also tried that ive cut the red wire from the injector harness and cut the red wire from the ecu (a3 i think it was) and connected those together directly (bypassing the harness all together) still f*cked up. could it be the connector that plugs into the ecu? how often do those go bad?
Old May 27, 2003 | 10:50 AM
Pelican's Avatar
prob not the ecu. You might have the harness incorrectly grounded, like souble powered. Its a stretch, but I did it once. Same thing. But it fries the injector driver, so the ECU might be worthless.
Are you getting a check engine light?
Old May 27, 2003 | 11:32 AM
jazz215's Avatar
Default Re: cylinder flooding with gas (Pelican)
oh yeah,,, i forgot to mention, cel is on for engine misfire (prolly due to the flooding).
is there anything else that would affect the injector not "pulsing" open and closed? if the pgm-fi main relay was broken, would it cause all the injectors to stop working? or just one?
Old May 27, 2003 | 12:41 PM
EFb18b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jazz215 &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah,,, i forgot to mention, cel is on for engine misfire (prolly due to the flooding).
is there anything else that would affect the injector not "pulsing" open and closed? if the pgm-fi main relay was broken, would it cause all the injectors to stop working? or just one?</TD></TR></TABLE>
CEL on and is the code actually #2 cylinder misfire or engine misfire. The thing with honda's is that they have to tendency to go super rich to "a" cylinder or "all" cylinders(can't remember which) either way is a fail safe to prevent knock. Are you sure you have teh right kind of injector? take the clip cover off and inspect it for shorts. check the knock sensor. check the o2 sensor. hell check the MAP sensor. The trick is don't look in one specific spot. You have to look at EVERYTHING that has to do with fuel usage or fuel itself. Hell, did you reset the ECU? I know it sounds stupid but I've forgotten to do it. The best thing to do is grab a fluke and start testing. Find out for yourself what it is then when someone else has the problem you can tell them where to look
I used to be an auto electrician and you don't want to know what we charge.
Old May 27, 2003 | 12:44 PM
dennis's Avatar
Just an idea, would it be flooding cause there's no spark to burn it? Check that plug for spark.
Old May 28, 2003 | 02:58 PM
jazz215's Avatar
Default Re: cylinder flooding with gas (dennis)
i have replaced the plugs and wires. now as for the ecu resetting, doesnt it reset when you unplug it then plug it back in? also the injectors themself are good. i havent checked the sensors, but ill do that this weekend.
when i start the car, it sputters, but if i unplug the wiring from injector 2 and let the engine burn the extra fuel in the cylnder, it will run fine for a sec. until all the fuels gone. so when i connect the injector wiring and disconnect, reconnect, discconnect.. etc... it will run fine. ( so basically im just simulating the "pulsing" effect)
what tells the injectors to open and close?
this is the worst problem ever!!!!!
Old May 28, 2003 | 03:55 PM
Jared's Avatar
Does your car have an injector resistor box? what year, what car, what ecu, what engine? what injectors?
Jared's Avatar
Default Re: cylinder flooding with gas (Jared)
by the way, have you verified that cylinder has a consistently good spark?
Old May 29, 2003 | 03:51 PM
jazz215's Avatar
no resistor box, 94 civic, p28, d16z6 automatic stock injectors. i just had engine rebuilt. also i know the engine has spark in all 4 cylinders, if i plug the #2 injector wiring to cylinder 3, #3 wont work. and when i plug the #3 wiring to cylinder #2, 2 will work and 3 wont. so seemed to be a harness problem, but i replaced a harness (expensive )
Old May 29, 2003 | 03:52 PM
jazz215's Avatar
you think alarm wiring could be a part in all of this? thats the only other non stock thing on my car thats electrical.
Old May 30, 2003 | 07:20 AM
KurumaTuning's Avatar
just a shot in the park....are u running any kind FPR?
Old May 30, 2003 | 11:34 AM
jazz215's Avatar
completely stock fuel system.
Vtec04
Sep 28, 2017 05:05 PM
Brycen
Mar 18, 2012 07:13 AM
CARMA_626
Dec 25, 2008 12:24 AM
my91civic
Jul 6, 2003 06:13 PM
