EEs help....traction control idea.
Old May 26, 2003 | 12:01 PM
JM Performance's Avatar
Default EEs help....traction control idea.
Alright so TOO has traction control on some of his cars that seems to work good.
They all work off of the same princaple. Using wheel speed sensors (ABS) compare the speed of the rear wheels to the speed of the front wheels. If the front wheels move faster than the rears by an adjustable amount then do something.
On his SCed ITR he opens the bypass valve and lowers boost...a fantastic idea.
On his civic he cuts spark.
Now for the life of me I can't think of lowering boost enough to fix traction w/ a turbo without overspinnging the turbo. You'd have to open the wastegate somehow.
But what you can still do is cut spark. I have a MSD soft revlimiter which pulls spark from alternate cylinders. Would this be safe for a turboed car? Or could the gas still ignite once outside of the cylinder?
Also, and EE's know how to make the circutry to run this thing? You need something that can compare the voltage (or is it frequency) of the wheelspeed sensors and when fronts exceed rear by amount (using a dial would be good) it sends out a voltage which would run whatever.
Opinions, idea, flames?
Old May 26, 2003 | 01:20 PM
ion_four's Avatar
Default Re: EEs help....traction control idea. (00SilverLS)
Very good idea, makes me wish I had ABS
The ABS sensors output a frequency, I believe...the easiest thing to do would be to convert the frequencies to voltages and compare them. All the MSD "pills" are just resistors, so you wouldn't even need the two step, just something to momentarily raise the resistance so that the rev limit is lowered...how you would do that is beyond me at the moment...I'm sick, can't think
Old May 26, 2003 | 03:03 PM
echo999's Avatar
New User
For what it's worth. v1.0 of the AEM EMS has traction control. It looks
at your vehicle speed sensor, and activates if the change in the voltage
exceeds defined limits.
Old May 26, 2003 | 05:38 PM
Full-Race Geoff's Avatar
Default Re: EEs help....traction control idea. (echo999)
a better, although less accurate idea (better becuase not everyone has ABS) is to use a g-tech pro type accelerometer and compare that to the speed sensor... i actaully did an engineering project on this exact topic 3 years ago. I can try to find my files if you are really interested.
Old May 26, 2003 | 06:49 PM
racerxadam's Avatar
I believe the way the EMS traction control will work is to log max acceleration in each gear without wheelspin and input that data into tables according to gear then the software will be able to tell when the limit of max acceleration is exceeded and turn on a ignition retard. the only problem i see is being able to log max acceleration for the lower gears. seems like it would have to be done on a dyno with slicks for some of the real high horsepower cars or the ever reliable trial and error.
Old May 26, 2003 | 06:58 PM
Muckman's Avatar
Moderator in Chief
Has anyone experimented with the traction control in the AEM EMS? I just ordered my EMS and curious how well it works
Old May 26, 2003 | 07:02 PM
seekerONE's Avatar
http://www.racelogic.co.uk/tc-brief.htm
Old May 27, 2003 | 02:32 PM
racerxadam's Avatar
Default Re: EEs help....traction control idea. (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone experimented with the traction control in the AEM EMS? I just ordered my EMS and curious how well it works </TD></TR></TABLE>
not likely since aem hasn't released the new firmware/software for current users, v 1.0 is only shipping with new units and they don't have base maps out yet either.
hello1320
Dec 23, 2009 06:48 AM
pete5990
Mar 17, 2007 05:29 PM
f1 vtec
Jul 9, 2004 01:51 PM
fredtoast
Oct 9, 2003 08:31 AM
romeo619romeo
Jul 15, 2003 01:09 AM
