sohc turbo....tranny problems?
Old May 25, 2003 | 10:03 AM
yusoslo's Avatar
Default sohc turbo....tranny problems?
I am having trouble making up my mind on the motor swap I want. I have a DX hatch right now with an oil burning motor.
I can get the d16z6 swap for around 600 bucks and turbo it very soon, but how strong are the transmissions on those engines??
I could also shell out the extra cash for a ls, but then I wont be able to go tubo for a while.
All I want is a daily 13 sec car.
In a nut shell, will a D16z6 tranny handle 13 sec 1/4 mile power?? consistantly
Old May 25, 2003 | 10:04 AM
Boltz's Avatar
Default Re: sohc turbo....tranny problems? (yusoslo)
yea, as long as its in good condition... might want a new clutch for the higher performance
Old May 25, 2003 | 10:06 AM
Boltz's Avatar
Default Re: sohc turbo....tranny problems? (Civic420)
get a Y8 block, Y8 mani, Z6 head, z6 ecu, and Y8 tranny if you can.
Old May 25, 2003 | 10:14 AM
TurboSedan's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic420 &raquo;</TD></TR><TR><TD CLASS="quote">get a Y8 block, Y8 mani, Z6 head, z6 ecu, and Y8 tranny if you can.</TD></TR></TABLE>
I have all of those except the Z6 head. The Z6 P28 ECU was required to use the Hondata! Other than having a slightly lower CR, what other reason is there to use the Z6 head?
Old May 25, 2003 | 10:52 AM
turbod16y8's Avatar
Default Re: sohc turbo....tranny problems? (TurboSedan)
the tranny will be OK,. just make sure u dont get too much wheel hop. or the tranny will go for sure...
Old May 25, 2003 | 10:59 AM
Racerage1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSedan &raquo;</TD></TR><TR><TD CLASS="quote">
I have all of those except the Z6 head. The Z6 P28 ECU was required to use the Hondata! Other than having a slightly lower CR, what other reason is there to use the Z6 head? </TD></TR></TABLE>
Z6 head flows better
Old May 25, 2003 | 11:07 AM
yusoslo's Avatar
Default Re: sohc turbo....tranny problems? (Racerage1)
would it be pointless to build my d15b? The tranny is weak i hear, but I would have a solid bottom end. Or would a low milage stock d16z6 be better for turbo ( I am looking for 10 lbs of boost) that should equate to a little over 200 whp tuned
Old May 25, 2003 | 04:03 PM
Mista Bone's Avatar
D Tranny Guru
Kaaz LSD
Old May 25, 2003 | 09:59 PM
Broken Gearbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yusoslo &raquo;</TD></TR><TR><TD CLASS="quote">would it be pointless to build my d15b? The tranny is weak i hear, but I would have a solid bottom end. Or would a low milage stock d16z6 be better for turbo ( I am looking for 10 lbs of boost) that should equate to a little over 200 whp tuned
how much money do you want to spend???
i say swap in the Z6 and boost that
Old May 25, 2003 | 11:37 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racerage1 &raquo;</TD></TR><TR><TD CLASS="quote">
Z6 head flows better</TD></TR></TABLE>
i always thought the y8 head flowed better. especially due to the intake manifold
Old May 25, 2003 | 11:46 PM
rjardy's Avatar
Default Re: sohc turbo....tranny problems? (CivicRyda2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">
i always thought the y8 head flowed better. especially due to the intake manifold</TD></TR></TABLE>
correct!
Rob
Old May 26, 2003 | 12:04 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: sohc turbo....tranny problems? (rjardy)
Z6 head, Y8 intake manifold for best flow with stock parts.
TheDrizzle50
21
Sep 21, 2007 04:23 AM
blackhope121
Jul 2, 2007 11:37 AM
puertoroc7976
Sep 21, 2006 08:14 AM
rasinhell
16
Jan 14, 2005 08:05 AM
al3e
17
May 4, 2004 11:44 AM
