Tuning a V-AFC without dyno
Old May 25, 2003 | 09:09 AM
BAZ's Avatar
BAZ
Default Tuning a V-AFC without dyno
I need help tuning my v-afc without a dyno. Does anyone out there have a b18c1 or similar block that has a t3/t4 (drag kit) 450cc DSM injectors, walbro 255 high pressure fuel pump, and 2.5 inch exhaust all the way back off the turbo? I am currently running 10psi. I lean out at about 5400 rpm, right before v-tec engauges. I was just curious to know if anyone with a similar setup could post their settings on a v-afc. Thanks and please dont tell me to get it dyno tuned. I will when it is running good enough to get it 135 miles to Illionois from Wisc.
Old May 25, 2003 | 09:44 AM
SolidSpruce's Avatar
Default Re: Tuning a V-AFC without dyno (BAZ)
what do u have the high cam fuel correction set to? -35 would be pretty rich before throwing a cell at about 10.5-11psi.
Old May 25, 2003 | 10:54 AM
c1hatch's Avatar
Default Re: Tuning a V-AFC without dyno (SolidSpruce)
How do you know you are leaning out without proper A/F readings?
Old May 25, 2003 | 12:16 PM
BAZ's Avatar
BAZ
Default Re: Tuning a V-AFC without dyno (c1hatch)
i have a autometer a/f gauge that says i am leaning out and the car bogs down when hitting v-tec but i am assuming that i could just be running to rich considering how deadly accurate the gauges are. My high cam is set at -27. If anything i am runnning way to rich when v-tec kicks in. My tuning up to v-tec seems right but a bit rought when downshifting. let me know what setting should be if you have similar experience and insight. thanks
Old May 25, 2003 | 12:47 PM
swlabhot's Avatar
1st off, I hope you're not relying on the Autometer A/F gauge for your a/f mixture as it doesn't tell you precisely how rich or lean you are running at all. If it indicates in the lean LED range then you're already in serious trouble.
-27 trim is too rich for 440cc. You should be closer to -40% which explains why the car bogs down on the high cam.
I'm using 500cc and my settings are like -48 to -45 from 1krpm to 8.5krpm. It seems to run pretty good so far.
Old May 25, 2003 | 01:44 PM
lsvtec101's Avatar
Default Re: Tuning a V-AFC without dyno (swlabhot)
quick question, on the ne:LvT and ne:HvT
ne:Lvt
ne1: 1000
ne2: 2000
ne3: 3000
ne4: 4000
ne5: 5000
ne6: 6000
ne7: 7000
ne8: 8000
ne:Hvt
ne1:3000
ne2:4000
ne3:4500
ne4:5000
ne5:5500
ne6:6000
ne7:7000
ne8:8000
for the ne:Hvt i couldnt go any lower than 3000 on the first ne1...
does this look O.K?
Old May 31, 2003 | 03:56 PM
lsvtec101's Avatar
Default Re: Tuning a V-AFC without dyno (aemcivic_02917)
ttt can any1 answer my question? thanks
Old May 31, 2003 | 04:12 PM
rjardy's Avatar
Get a wideband o2, thats the best way to tune without the aid of a dyno. Evan though the most helpfull thing on the dyno just happens to be the wideband o2...
I paid 400 for mine, there not as expensive as you might think.
Rob
Old May 31, 2003 | 04:27 PM
lsvtec101's Avatar
Default Re: Tuning a V-AFC without dyno (rjardy)
i live in rhode island and i know this 1 dyno and he tunes mustangs, i doubt he can tune a vafc... how do i tune this afc by myself @ a dyno. any tuners out there??
edit:
my setup
walboro 255
RC 440CC
vafc
d16y8 head
d16y8 headgasket
d16y7 bottom end
dont know my exact compression i think its around 10:2 ??? what should my air fuel ratio be????
Old May 31, 2003 | 04:38 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemcivic_02917 &raquo;</TD></TR><TR><TD CLASS="quote">i live in rhode island and i know this 1 dyno and he tunes mustangs, i doubt he can tune a vafc... how do i tune this afc by myself @ a dyno. any tuners out there??
edit:
my setup
walboro 255
RC 440CC
vafc
d16y8 head
d16y8 headgasket
d16y7 bottom end
dont know my exact compression i think its around 10:2 ??? what should my air fuel ratio be???? </TD></TR></TABLE>
Bogging is generally due to being to rich. As far as tuning goes, make a pull, then look at your air/fuel ratio readings and make adjustments accordingly. oh and the air/fuel ratio gauge is pointless
Old May 31, 2003 | 04:56 PM
lsvtec101's Avatar
Default Re: Tuning a V-AFC without dyno (b16ahybrid)
ok thanks, another question the
[ V/T Cont ]
H&gt;L 5800
L&gt;H 5400
throttle: 15 low 70 high
what should this be set to if my settings are...
ne:Lvt
ne1: 1000
ne2: 1500
ne3: 2000
ne4: 2500
ne5: 3000
ne6: 3500
ne7: 4000
ne8: 4500
ne:Hvt
ne1:4600
ne2:5000
ne3:5500
ne4:6000
ne5:6500
ne6:7000
ne7:7500
ne8:8000
Old May 31, 2003 | 08:29 PM
CivicSoul's Avatar
Make it simple on your self and safe for your car. If it is bogging, it is rich, drive it like an old vw bus to the dyno and go from there.
these are my settings
3 -53%
4 -51%
5 -49%
6 -47%
7 -45%
and the 500's are in between
you should be at about 5% less all through out the rpms.
PLAY IT SAFE!
Old May 31, 2003 | 09:17 PM
FastNFurious
Guest
Posts: n/a
Do you really have to hit VTEC on your 135 mile drive? I know its hard but just try and not floor it on the way there.
sagron69
Mar 18, 2004 02:11 AM
[ iLL ] iNt3GrA
Dec 17, 2003 08:25 PM
ActiveAero
Mar 3, 2003 11:58 PM
IgniteTeg
Sep 18, 2002 11:19 PM
TurBoXBirD16
Jul 9, 2002 08:37 AM
