afc and 450's install car wont start
hooked up the turbo today...using afc with 450's tried starting the car at -35 and
-40 wont start....not gettin any spark for some reason..check the plugs and they were a little wet, not much
ps: at first i tried starting it with the 10ohm 10watt resistors on the the lead wire of the injectors-double checked directions, put them on neg wires...no blown fuses(could be wrong)
any help would be appreciated thanks!
Re: afc and 450's install car wont start (krazySOHC)
u may have flooded ur engine with fuel.. try taking out your plugs and cranking it over a couopple of times. then reset the ecu then try to start her up..
you might not getting any spark. try checking all your fuses in the engine bay and under the dash especially the ignition fuse under the dash.
Re: afc and 450's install car wont start (_Endless_)
checked them...still no spark....which fuses in particular are you talking about? ....ill go double check
Re: afc and 450's install car wont start (ash.zero)
if your not getting any spark then check your coil and/or distributor components. Just follow your helms and check for troubleshooting "not getting spark" this happened to me and it turned out my coil was bad
you checked all ignition components??? was your vafc working before or did you do everything at once??? check all wiring at your computer and if that doesent work return it back to stock and see if it starts then
double check to make sure you have spark. pull plugs and wires and connect a plug to the wire and have some one give it a real quick crank. you will see a good spark. you might have washed your plugs and cylinders if you flooded it badly with your settings. similar thing happened to me. this may help:
https://honda-tech.com/zerothread?id=508621
good luck.
good luck.
Re: afc and 450's install car wont start (scttydb411)
STILL NO DAMN SPARK....i uninstalled the afc and still, no spark, no blown fuses....i dont get it it!!!.....afc works fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazySOHC »</TD></TR><TR><TD CLASS="quote">checked them...still no spark....which fuses in particular are you talking about? ....ill go double check</TD></TR></TABLE>
it's a 15A fuse under the dash. this fuse blew after i installed my msd6a i thought i was doomed coz i can't find what's wrong so i checked the fuses i think relates to fuel and ignition and found that 15A fuse.
double check your afc wiring and check the calibration process.
no blown fuses and im not getting spark from the wires.....i am stumped ..afc wiring is good
Modified by krazySOHC at 3:32 PM 5/28/2003
solk1dd
15
02-07-2005 01:50 PM
