GM 3bar Map sensor problems
Old May 24, 2003 | 04:24 PM
boosted hybrid's Avatar
Default GM 3bar Map sensor problems
Quick questions for everyone. I have installed and tuned a few 3 bar map sensors, but I havent ever asked around where everyone gets them. I decided to order a 3bar map sensor a month ago from GMPartsDirect.com. I got the correct part numbers, order the sensor and it looked identical to the others that I used in the past. I installed the sensor today on a customers car, Hondata did not seem to like it at all. It acted identically if you were to just start up the car with a 3bar map sensor on the stock computer. The idle was rough, extremely rich. Hondata was set up in the maps for the 3bar sensor, and I tested the voltage output of the sensor. Before the engine was turned over it didnt give the characteristic 1.67 volts, it was 1.85 volts. We pulled off the sensor, put on the stock one an headed to the dyno. Where does everyone order their 3bar's from that runs Hondata? I have always had the customers bring me the sensor and installed it with zero problems, and my personal 3bar sensor came from a Haltech wire harness kit.
Old May 24, 2003 | 05:31 PM
sleepy's Avatar
Default Re: GM 3bar Map sensor problems (boosted hybrid)
Hondata recognizes that it's software is having issues with the GM 3 bar sensor. There is a software update V3.5.1 that addresses calibrations as many tuners have noticed that calibrated mechanical and electronic boost gauges disagree with hondata's interpretation of boost pressure. Perhaps your sensor is a 2 bar version?
Check in the "Bugs" section of the Hondata forum and then download the new version of RomEditor.
I am sure GruvyTune can help you.
Good luck
Old May 28, 2003 | 01:39 PM
lazerus's Avatar
Default Re: GM 3bar Map sensor problems (sleepy)
I've gotten sevearal sensors from gmpartsdirect.com a good place to get'em!
Old May 28, 2003 | 02:39 PM
intekragsr's Avatar
Default Re: GM 3bar Map sensor problems (lazerus)
hmmm. I have the 16040749 sensor. I hope mine works. Are they all the same model number as mine? The box mine came in was a ACDelco box. Yours too?
Old May 28, 2003 | 07:41 PM
IloveNewt's Avatar
Check wiring. I have a GM 3 bar, and my rough start/stalling, idle problem is from bad wiring, used damn butt connetors. I soldered it and no probs now.
Old May 28, 2003 | 08:19 PM
95c1v1cs1's Avatar
Default Re: GM 3bar Map sensor problems (MordecaiPSI)
I had no probs hooking mine up and working. double check wiring. I got mine from gmparts direct. someone sent me a link to the different map sensors and i just copied and pasted that number for the 3bar. They actually sent me a different part number but it worked fine.
Edit- you said it came with a wiring harness, try to find a piggy back from the junk yard. I found a million of them when i went there.
Corey
Old May 28, 2003 | 08:59 PM
DragEG6 FI's Avatar
Default Re: GM 3bar Map sensor problems (95c1v1cs1)
same here...got mine from GMparts......had a problem at first but it was wiring...
Works like a champ now
Old May 28, 2003 | 09:35 PM
Default Re: GM 3bar Map sensor problems (Boost`n.eg^b18c1)
I havent had the time to check if its a 2bar or 3bar map sensor or not. I have a feeling that they didnt send me the correct sensor. The wiring was correct, and soldered as well. I double checked the voltage drop across each connection as well, and everything was correct. I have hooked up at least 5-6 of them already with zero problems. This is the first to cause a headache.
Old May 28, 2003 | 09:47 PM
VaporTrail's Avatar
New User
I get my 3 bar map sensors from Hondata or MSD, depending on if I feel like chasing down the pig tail connectors or not.
Old May 31, 2003 | 07:35 AM
Neukin's Avatar
Default Re: GM 3bar Map sensor problems (VaporTrail)
how much do you guys pay for those around 90?
Old May 31, 2003 | 09:30 AM
sweet's Avatar
Default Re: GM 3bar Map sensor problems (toyosupr)
i've been hearing about problems with the GM MAP sensors for awhile now, the fact that some that are supposed to be or thought to be 3 BAR aren't therefore making problems with tuning using Hondata. it seems that most people get the 3 BAR MAP from the GM direct site, but not all sensors gotten have worked properly with Hondata. so that makes me think twice about randomly ordering a GM MAP that's supposed to be 3 BAR but may not be.
there was a recent thread about using the MSD and GM MAP sensors with Hondata.
i asked what # i should look for when trying to pick up the correct MSD or GM 3 BAR MAP sensor but never got an answer. i'd hate to spend the extra $$ on the Hondata MAP if i can locate the correct MSD or GM one.
hope it gets straightened out! prolly just sent the wrong sensor, not a 3 BAR.
b18_eg
Engine Management and Tuning
Jul 22, 2017 12:31 PM
GT500FTW
Apr 11, 2014 10:15 AM
lucidvtec
Jul 11, 2005 11:51 PM
