compression ratio on d15B
Old May 23, 2003 | 08:25 PM
vtekar's Avatar
Default compression ratio on d15B
wat is the factory compression ratio on a d15b
Old May 23, 2003 | 08:27 PM
sweet's Avatar
Default Re: compression ratio on d15B (vtekar)
i believe the D15B7 from the 92-95 Civic DX/LX is 9.2:1 C/R just like the D16Z6 motor from the 92-95 Civic EX/SI.
Old Jun 3, 2003 | 09:08 PM
NatedoggAZ's Avatar
Default Re: compression ratio on d15B (sweet)
I have the same D15B7 in my '92 Civic. What PSI (on average) should we expect to see accross all cylinders with that ratio?
THX!
N
Old Jun 3, 2003 | 09:13 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sweet &raquo;</TD></TR><TR><TD CLASS="quote">i believe the D15B7 from the 92-95 Civic DX/LX is 9.2:1 C/R just like the D16Z6 motor from the 92-95 Civic EX/SI.</TD></TR></TABLE>
Yep the d15b7 has 9.2:1 compression, but the d16 has 9.5:1 compression.
Old Jun 3, 2003 | 09:14 PM
b16ahybrid's Avatar
Default Re: compression ratio on d15B (NatedoggAZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatedoggAZ &raquo;</TD></TR><TR><TD CLASS="quote">I have the same D15B7 in my '92 Civic. What PSI (on average) should we expect to see accross all cylinders with that ratio?
THX!
N</TD></TR></TABLE>
Within 10% of eachother. not sure what it would read on a compression test
Old Jun 3, 2003 | 09:32 PM
5thgencivic's Avatar
Default Re: compression ratio on d15B (b16ahybrid)
D16Z6=9.2:1 C/R
Old Jun 4, 2003 | 08:24 AM
sweet's Avatar
Default Re: compression ratio on d15B (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">D16Z6=9.2:1 C/R</TD></TR></TABLE>
yep that is what i was referring to in my original post, not the D16Y motor which i believe has 9.5:1 C/R. all the D16Z6 motors had 9.2:1 C/R just like the D15B7.
Old Jun 4, 2003 | 08:27 AM
sweet's Avatar
THX!
N</TD></TR></TABLE>
i don't do compression tests normally cause i don't have the gauge setup yet, but when people post up their cylinder psi readings they're normally in the 180-200 range. but of course some are higher/lower depending if they're stock or not, if the C/R was increased or decreased etc. some readings may be well above the 200 range, and some below 170-180 range too.
valiente540
Feb 2, 2008 11:38 PM
stealth89hatch
16
Jun 19, 2005 10:37 AM
LorenGeist
Nov 23, 2004 09:59 PM
93civiccxhatch
Nov 6, 2004 09:32 PM
Btothe3rdDegree
10
Sep 7, 2003 05:29 PM
