CAI to charge pipe?
Old May 27, 2003 | 12:00 AM
thaiphob's Avatar
Nikon!!!
Default CAI to charge pipe?
just wondering if it is possible to convert a AEM CAI for a LS into a charge pipe for a turbo? has anyone ever done/seen one done? just wondering if it is possible?
Old May 27, 2003 | 05:34 AM
scttydb411's Avatar
Default Re: CAI to charge pipe? (thaiphob)
i'm using my cai as part of my chage piping. you will have to disconnect the breather tube from the valve cover and hoseclamp a bolt into it to plug it and then put a breather filter on the valve cover or reroute it to your intake before the turbo.
Old May 27, 2003 | 05:53 AM
Tinker219's Avatar
Default Re: CAI to charge pipe? (scttydb411)
all the above, and Ive done it many times. works great !
Old May 27, 2003 | 08:21 AM
silly sohc's Avatar
Default Re: CAI to charge pipe? (Tinker219)
If anytime you can get ahold of the front mount intakes they also work great for ic piping.... we have a couple ppl up here who have used them.
Old May 27, 2003 | 09:22 AM
MikeMAN's Avatar
yup, done it before. works GREAT!
mike
Old May 27, 2003 | 09:26 AM
dfoxengr's Avatar
yeah we didi that on my friends turbo, just measure and hack it up
Old May 27, 2003 | 01:27 PM
thaiphob's Avatar
Nikon!!!
Default Re: CAI to charge pipe? (hybridvteceg)
cool guys thanx for the info. any pics?
Old May 27, 2003 | 01:41 PM
red_sir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 &raquo;</TD></TR><TR><TD CLASS="quote">i'm using my cai as part of my chage piping. you will have to disconnect the breather tube from the valve cover and hoseclamp a bolt into it to plug it and then put a breather filter on the valve cover or reroute it to your intake before the turbo.</TD></TR></TABLE>
Umm what happens if you don't disconnect the breather tube? Cause I'm using a AEM cai right now but I didn't do that. Thanks.
Old May 27, 2003 | 02:13 PM
Brad's Avatar
The way I have it, the port on the AEM is being used as a vacuum/boost source, connected to the wastegate.
Old May 27, 2003 | 02:25 PM
omahaturbocivic's Avatar
Default Re: CAI to charge pipe? (red_sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_sir &raquo;</TD></TR><TR><TD CLASS="quote">
Umm what happens if you don't disconnect the breather tube? Cause I'm using a AEM cai right now but I didn't do that. Thanks.</TD></TR></TABLE>
You are sending boost pressure into your engines crankcase. Where it goes from there I dunno, could shoot out your dipstick.
scttydb411's Avatar
here ya go. i just slipped a 1/2 inch bolt in the breather hose and hoseclamped it.
i then put a breather filter on the valve cover.
intekragsr's Avatar
Default Re: CAI to charge pipe? (Brad)
isnt the pipe aluminum? it will be hard to weld a blow off valve onto there right?
Old May 27, 2003 | 02:36 PM
Hayasa15's Avatar
Default Re: CAI to charge pipe? (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">isnt the pipe aluminum? it will be hard to weld a blow off valve onto there right?</TD></TR></TABLE>
then you can put your bov before the intercooler
Old May 27, 2003 | 11:50 PM
ludelvr's Avatar
Default Re: CAI to charge pipe? (Hayasa15)
A buddy of mine did that with an AEM CAI and he even had an HKS BOV flange welded on.
Old May 28, 2003 | 12:23 AM
MikeMAN's Avatar
shouldn't be, u just need to get an aluminum flange and have a farily competent welder
mike
Old May 28, 2003 | 02:10 AM
scttydb411's Avatar
i welded my bov to my steel charge piping between the end of my cai and my fmic. it's mounted in the front bumpter where the filter used to be. it's a 1g dsm bov. i found a small k&n filter to mount on it so it doesn't suck up crap while cruising in vacuum open.
Old May 28, 2003 | 11:37 PM
thaiphob's Avatar
Nikon!!!
great guys! Thanx!
Old May 29, 2003 | 04:54 AM
T-RO's Avatar
WOuldnt it be a better idea to get a generic CAI off Ebay for $40 and use that? AEM CAI's are damn expensive, its better to cut up a cheap one and save or sell the AEM.
My thoughts
Old May 29, 2003 | 08:15 PM
scttydb411's Avatar
Default Re: (T-RO)
i'm using my entire aem cai and did absolutely no modification to it (cutting, welding, etc). the only thing i did to it was disconnect the breather line and plug the actual hose.
Old May 29, 2003 | 08:26 PM
Daniel's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">WOuldnt it be a better idea to get a generic CAI off Ebay for $40 and use that? AEM CAI's are damn expensive, its better to cut up a cheap one and save or sell the AEM.
My thoughts </TD></TR></TABLE>
If you're going from NA to FI and already have an AEM CAI, why waste another $40? Use what you have.
tytyguy
Apr 13, 2006 01:40 PM
PearlBlueType-S
10
Dec 25, 2005 01:34 AM
cambopheonix56
May 19, 2004 09:46 AM
AirWaveGT
Mar 28, 2004 08:41 PM
LethalX
Apr 20, 2002 01:10 AM
