Does anyone see anything wrong
Old May 26, 2003 | 12:52 AM
EG6owner-T's Avatar
Default Does anyone see anything wrong
with this:
this is how I got it from Avatar, so is there a special way to put it together cause the prob will come out, the ways I did it.
Its the greddy egt gauge, if anyone can help me I would appreciated, thanks.
Old May 26, 2003 | 04:25 AM
wHOAlly's Avatar
Default Re: Does anyone see anything wrong (EG6owner)
looks like a compression fitting to me...thread that threaded silver piece on the left into the manifold/dp or watever, then put that silver piece in the middle onto the probe, then put that silver piece on the right onto the prob, then screw it onto the piece on the left that was threaded into ur mani/dp
Old May 26, 2003 | 04:29 AM
racerxadam's Avatar
Default Re: Does anyone see anything wrong (Sp00n'd Supra)
agreed, and you actually have to tighten it with tools. your hands alone aren't enough to crush the ferrel and squeeze the probe.
Old May 26, 2003 | 05:24 AM
BigMoose's Avatar
If its a swagelok fitting it may have a two piece furle (or however it is spelled) and you may be missing the inner piece that goes against the fitting. The piece you have goes against the nut. Look for a swagelok web site for the drawing.
Old May 26, 2003 | 07:58 AM
TurboDANDEE's Avatar
Default Re: Does anyone see anything wrong (BigMoose)
u have to sandwich that compressor fitting onto the sensor. once u tightened the fittings with tools, it should hug the probe and will not slip out anymore.
Old May 26, 2003 | 08:03 AM
IloveNewt's Avatar
yea i was thinking the same thing with my greddy egt. Just do it how the instructions say and when u tighten it down well it will sandwich it in.
Old May 26, 2003 | 11:05 AM
EG6owner-T's Avatar
Default Re: Does anyone see anything wrong (MordecaiPSI)
thank you all
Old May 26, 2003 | 12:00 PM
lazerus's Avatar
Visualizations always help second is the ferule
p1ccoloz
Dec 20, 2004 10:15 AM
adictionbass
Welding / Fabrication
Dec 13, 2004 10:03 AM
Sohc Driver
Jun 10, 2004 04:12 PM
Ri5e
Sep 10, 2002 12:20 PM
