Compression ratio for supercharged B16
Old May 24, 2003 | 09:00 PM
McFly's Avatar
Default Compression ratio for supercharged B16
I have a B16 laying around and some LS pistons. I have a GSR head that has been milled .037" and I was planning to use it with a JRSC. Would it be beniffical to install the LS pistons to lower the compression and raise the boost to 10 or 12#? The compression would be 9.1 to 1. If I usd the B16 pistons and a thicker head gasket the compression ratio would be 10.2 to 1 and I thought it would be safer to run the added boost on a lower compression engine. I don't want the car to be a dog at the lower compression though. Anyone ever tried this?
Old May 25, 2003 | 07:33 AM
McFly's Avatar
bump
Old May 25, 2003 | 07:47 AM
Jonny Black's Avatar
Default Re: (UnderFire)
at 10 lbs of boost, the more stock compression of 10.2 to 1 would more ideal, with propure tunning.
Jon
Old May 25, 2003 | 08:53 AM
blacksheep's Avatar
Default Re: (Jonny Black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny Black &raquo;</TD></TR><TR><TD CLASS="quote">at 10 lbs of boost, the more stock compression of 10.2 to 1 would more ideal, with propure tunning.
Jon</TD></TR></TABLE>
I agree
Old May 25, 2003 | 09:46 AM
SolidSpruce's Avatar
Default Re: (blacksheep)
ya make more power with the higher compression. just make sure ur rods can hold its new found power safely
Old May 25, 2003 | 09:52 AM
CRVRX's Avatar
Default Re: (SolidSpruce)
Go with the higher compression. I build supercharged motors between 10 and 10.5 to 1.
Old May 25, 2003 | 12:04 PM
McFly's Avatar
Thanks for the info. Guess I stick with B16 pistons.
Old May 25, 2003 | 12:40 PM
AlLMoToRvOtEr's Avatar
Ya go with the B16 pistons. I had a friend with a 2000 SI stock motor with a JRSC @10psi and the jackson racing ecu and fuel system and his car ran 12.9 on slicks.
Old May 27, 2003 | 01:51 PM
GreddySi99's Avatar
Default Re: (jdmhatch138)
if you want to make real power with the jackson supercharger use 11:1 pistons and low cool boost and good tuning. this will net you the most power for the buck!!!
99siRACER
Jan 3, 2012 12:20 AM
i20ar
Sep 17, 2005 12:48 PM
rudebwoy
May 24, 2005 01:30 PM
94teg_RS
Sep 13, 2004 05:16 PM
genop
Sep 17, 2003 10:45 PM
