arp headstuds.....lube?
Old May 24, 2003 | 07:00 PM
5thgen's Avatar
Default arp headstuds.....lube?
i have d16z6 headstuds and was wondering how to lubricate it. I do not have the arp moly lube, are there any alternatives i.e. different kind of moly (lube?), or 30w oil?
if so what would the torque specs be, thanks.
thanks in advance, i also have already searched and didn't find a definite answer on this.
Old May 24, 2003 | 09:56 PM
boosted_zc's Avatar
Default Re: arp headstuds.....lube? (5thgen)
I always lube my headstuds before installing them, i usually just use any 30w i have alu=yin around. It ensures you get an acurate torque. As for your torque specs, as soon as i find my chilton, i'll post em for ya.
Old May 24, 2003 | 10:03 PM
intekragsr's Avatar
hehe oops, i didnt install mine today with lube. I dont think it will hurt. Torque spec for arp is 72 pounds.
Old May 24, 2003 | 10:37 PM
MiraiZ's Avatar
Default Re: arp headstuds.....lube? (boosted_zc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_zc &raquo;</TD></TR><TR><TD CLASS="quote">I always lube my headstuds before installing them, i usually just use any 30w i have alu=yin around. It ensures you get an acurate torque. As for your torque specs, as soon as i find my chilton, i'll post em for ya.</TD></TR></TABLE>
Aren't you suppose to use the Moly lube that it comes with?
Old May 24, 2003 | 11:04 PM
intekragsr's Avatar
Default Re: arp headstuds.....lube? (MiraiZ)
mine did not come with any :X it was not a brand new set. What are the negative effects without moly or some sort of lube?
Old May 25, 2003 | 03:39 AM
boosted3g's Avatar
Default Re: arp headstuds.....lube? (intekragsr)
if you dont use lube you will not get the proper torque. Moly lube is available at any auto parts store, pepboys, autozone and others.
Old May 25, 2003 | 12:17 PM
5thgen's Avatar
Default Re: arp headstuds.....lube? (boosted3g)
so will I be ok with 30w oil and ~70 ft. lbs.?
Old May 25, 2003 | 12:26 PM
MotorMatrix.com's Avatar
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">
Aren't you suppose to use the Moly lube that it comes with?</TD></TR></TABLE>
there are tq specs for moly lube and for 30wt oil when you use ARP's. I use 30wt oil and tq mine 85lbs.
Old Jul 8, 2003 | 07:10 AM
servion's Avatar
Default Re: arp headstuds.....lube? (MotorMatrix.com)
You lube both sides of the stud, correct?
1sicef9
May 6, 2010 03:58 PM
delsoldrew
May 10, 2006 04:09 PM
EF9ZC
May 3, 2006 11:07 AM
