Question about my turbo's filter
Old May 26, 2003 | 01:05 PM
E Swift's Avatar
Default Question about my turbo's filter
This may be a dumb question, but I just installed my Blitz filter the other day, and was wondering if the filter will suck in all the heat from my turbo and manifold down below? Will this cause any problems? There is one other possibility of where I can place my filter, but, this seemed the most convenient.
Old May 26, 2003 | 01:20 PM
Tofurky's Avatar
Default Re: Question about my turbo's filter (E Swift)
i'd be concerned with the open wastegate pointed directly at that AC line...
Old May 26, 2003 | 01:23 PM
ridnmyhonda's Avatar
that does nothing but suck in hot air...did you tap into the back of your block for that oil feed hope so...i would look around at "cheap" intakes and try to find a design that will slither through the radiator lines and what not. Good luck man...also get a dumptube on the w/g thats no good on ac lines
Old May 26, 2003 | 01:39 PM
E Swift's Avatar
Default Re: Question about my turbo's filter (ridnmyhonda)
Actually, the WG isn't pointed directly at the AC. It may look that way from the pic, but, it points below it.
Old May 26, 2003 | 01:57 PM
TurboSedan's Avatar
New User
Safer to still use a dump tube, trust me.
Old May 26, 2003 | 02:08 PM
Muckman's Avatar
Moderator in Chief
Default Re: Question about my turbo's filter (TurboSedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSedan &raquo;</TD></TR><TR><TD CLASS="quote">Safer to still use a dump tube, trust me. </TD></TR></TABLE>
[Another newbie quetsion] Where do you guys run yout dump tubes? Just to the bottom of the engine bay?
Old May 26, 2003 | 02:14 PM
TurboSedan's Avatar
New User
Default Re: Question about my turbo's filter (Muckman)
Try into the downpipe. Sleeper!
Old May 26, 2003 | 02:51 PM
Tofurky's Avatar
it would be wiser to route the air filter on the other side of the radiator hose.
and as far as a dumptube, just point it away from something important.
Old May 27, 2003 | 01:53 PM
E Swift's Avatar
Default Re: Question about my turbo's filter (Ruckus138)
Well, I found a way to move the filter more to the left, so its not even over the turbo anymore.
How much are dumptube's?
dgdarien
Sep 26, 2017 04:50 AM
a1320addict
Jan 15, 2006 01:56 PM
riceball777
Oct 3, 2005 01:49 AM
Understeer
Feb 7, 2004 01:29 PM
