15.47@87.44mph
Old Apr 4, 2004 | 12:01 PM
95excoupe's Avatar
Default 15.47@87.44mph
Does this sound about right for my setup? That run was with a 2.2 60' on azenis at 16psi (thats tire pressure not boost)
95 Civic ex coupe
Greddy td05-15g Kit with emanage running stock 5.5psi
Stock 1.5" exhaust
Un-tuned
I was hoping for it to be a little faster but I defintly need an exhaust and it wasnt pulling like it does at night it was pretty warm out. So or
Old Apr 4, 2004 | 12:02 PM
showtymers619's Avatar
* B A N N E D *
Default Re: 15.47@87.44mph (95excoupe)
you should be in the 14's already... but depends where your from .... also run without an exhaust.. jsut straight downpipe.. you should be there...and also... dont drop the PSI on your tires... no need for that.. first do a run with it stock inflated... just make sure you do your burn out to get them a little sticky..
Old Apr 4, 2004 | 12:11 PM
1boostedcivic's Avatar
Default Re: 15.47@87.44mph (ShowTymers619)
stock exhaust and downpipe
go open downpipe, and just keep on running. Driving good on the streets and on the track are to different things. good luck
Old Apr 4, 2004 | 01:13 PM
illi Adik's Avatar
Default Re: 15.47@87.44mph (1zexxedcivic)
Open the DP and I garauntee you will be in the 14's no question.
Old Apr 4, 2004 | 01:29 PM
sohc_vtec 2NR's Avatar
mid 15s sounds good with your current setup, at least your running what your suppose to
Old Apr 4, 2004 | 01:35 PM
team703's Avatar
if you are using street tires dont burnout in the pit, water will get trapped inbetween the tire tread so drive around the pit and launch easy or burn up befor eht eburnout pit then drive around it
Old Apr 4, 2004 | 02:56 PM
ExVtec's Avatar
Work on the exhaust issue and tuning...and 14's will be your friend
Old Apr 4, 2004 | 02:58 PM
1point5CRX's Avatar
Default Re: 15.47@87.44mph (ExVtec)
plenty of power still uncovered in your setup
Old Apr 4, 2004 | 03:15 PM
91sihatch's Avatar
don't do a burnout with the azenis. They actually get more slick when they are warmed up.
Old Apr 4, 2004 | 03:16 PM
dunkd's Avatar
thats a greddy kit for yah
Old Apr 4, 2004 | 04:29 PM
boosted-delslow's Avatar
Default Re: (dunkd)
I thought that it would be a little faster than that but i could be wrong!!!!
Old Apr 4, 2004 | 04:39 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (boosted-delslow)
I watched a 2000 Si with a Greddy kit and a huge FMIC at 8psi go 16.0 three times in a row. I'm not a big fan of the Greddy kit.
Old Apr 4, 2004 | 04:52 PM
95excoupe's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">I watched a 2000 Si with a Greddy kit and a huge FMIC at 8psi go 16.0 three times in a row. I'm not a big fan of the Greddy kit.</TD></TR></TABLE>
I watched an rsx type s run consistent 16.7's some people cant drive...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">thats a greddy kit for yah</TD></TR></TABLE>
its at 5.5psi with NO exhaust its not horrible....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatch &raquo;</TD></TR><TR><TD CLASS="quote">don't do a burnout with the azenis. They actually get more slick when they are warmed up.</TD></TR></TABLE>
Yeah I didnt do a burnout and I ran the 15.4 then i did and ran a 15.6 with lots of wheelspin so you are probably right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point5CRX &raquo;</TD></TR><TR><TD CLASS="quote">plenty of power still uncovered in your setup </TD></TR></TABLE>
Thanks I think so too....
And for everyone else I will try and run open downpipe next time along with 8psi. I really dont get the lack of respect for the greddy kit though it was 1500$ with a tunable piggyback system, for that price you cant complain.
Old Apr 10, 2004 | 05:45 AM
13link EG's Avatar
maybe a little bit quicker at least high 14s
Old Apr 10, 2004 | 07:27 AM
VTC_CiViC's Avatar
Default Re: (13link EG)
Bigger exahust and a little tuning are your friends
On my Civic with a GReddy kit, I squeezed out a 14.63 @ 95 or 96mph on 6-6.5psi, but I had a 2.5" DP and 3" exahust and I think I was already on Hondata
Otis37
Aug 15, 2009 11:55 AM
mitsuman
Apr 9, 2004 02:34 PM
johnisenglish
Dec 26, 2003 08:19 PM
01ITR#700
Sep 16, 2002 10:23 AM
01ITR#700
Sep 5, 2002 12:27 PM
