STR throttle body?
I can get a STR 70mm throttle body pretty cheap. Would I see any advantages with a 1.6 SOHC motor with 12lbs of boost?
I also plan on changing the downpipe to a 3inch pipe if that matters. Possibly also the exhaust manifold.
Guest
Posts: n/a
what are you running for fuel management? Your running the greddy kit correct? My neighboor was making 215whp (stock greddy kit and Hondata s100b) on a non vtec sohc. I would look into fuel management before you worred about throttle boddies etc (if you dont' already have it)
I have a hondata system. The car runs very well, although it's set a bit rich.(sometimes lets out a fart between shifts)
I still have the greddy kit with all the original pipes, manifold, turbo, and down pipe. The downpipe has broken several times and I just kept welding it back together
Anyone else think this is good or bad?
I guess my biggest worry is that I only have my foot half way to the floor and I'm already at full power.
