Boost and Vacuum related issues..
Old Mar 31, 2004 | 09:36 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Boost and Vacuum related issues..
OK.. heres my question..
normal cars at idle have some source of vacuum. when under throttle.. vacuum lessens.
so.. when you add a turbo to the engine, a source of pressure is introduced, and now you don't have as much vacuum present.
my question.. what do you do about vacuum controlled instruments (hvac) and brake system? dont they work off vacuum, and now your adding pressure?
this question ponders myself and co-workers...
Old Mar 31, 2004 | 10:30 PM
Built B16A's Avatar
Default Re: Boost and Vacuum related issues.. (Built B16A)
late night bump...
Old Apr 5, 2004 | 06:15 AM
dutchmikkel's Avatar
when the gasvalve is closed you have vacuum so when not onder throttle there wil be no boost and there is vacuum...quiet simple i think.
with a jrsc it's a little diffirent there the boost is after the gasvalve but a bypass leave's the boost go round in youre manifold through the blower back in to the manifold again, the pistons are stil under vacuum so you dont have any probleem with the brake system.
i'm running a jrsc but still have a problem with idle and when of throttle the rpm's seem too hang for a few second's....where it comes from ....i really don't know
Freshdot
Jun 21, 2010 08:04 AM
vtak2nr
Aug 27, 2009 03:59 AM
ZCcivic91
Sep 9, 2007 07:26 PM
99teggsr
Jun 1, 2005 09:39 PM
InTeGrA B18b1
Jun 2, 2003 03:26 PM
