What should I get done to my head?
Hey whats up I have a d16z6 head that I am preparing for turbo. I'm going to have new valves, springs and retainers installed along with a 3 angle valve job, resurfaced. Anything else I should do to prepare it better for boost? THanks
Re: What should I get done to my head? (00CIVICSITEIN)
I think you for got some cams too . I mean 1 cam since it's a sohc. Is the bottom end still stock?
Depending on the amount of boost you want to run, you might want to have some porting done. Unless you're going for all-out power, however, this is usually just a lesson in diminishing returns. Aftermarket cams are typically the same, although people have been claiming that the EF1 (I think that's it) cams are giving very good results.
spoonhatchblack
10-05-2007 11:10 PM
