Turbo people list your Fuel Management Setups HERE
thought i would ask the question after seeing it going on in the all motor forum.. Compression-
Injectors-
Fuel pump-
Fuel pressure regulator-
Fuel pressure-
What fuel management system you use-
Hp(if you have dynoed or a guess)-
Turbo size-
Modified by jkjb16a at 12:43 AM 4/6/2004
Injectors-
Fuel pump-
Fuel pressure-
Turbo size-
Re: Turbo people list your Fuel Management Setups HERE (jkjb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jkjb16a »</TD></TR><TR><TD CLASS="quote">thought i would ask the question after seeing it going on in the all motor forum.. Compression-
Injectors-
Fuel pump-
Fuel pressure-
Greddy 720cc injector
Walbro 255 intank
Stock Fuel Press. reg.
InlinePro rail
Hondata s200 w/ boost option
323hp 270tq @12.5psi
Injectors-
Fuel pump-
Fuel pressure-
Walbro 255 intank
InlinePro rail
RC Engineering 440cc Injectors
Walbro 255lph In-tank fuel pump
Stock fuel pressure regulator
Apexi SAFC-2
Estimated power: 200whp 185wtq @10psi (d16y7)
Apexi SAFC-2
Re: (Shocka1998LX)
In the middle of build
going with 9:1 compression
750 rc injectors(when i buy them)
Walbro 255 intank
Aem fuel rail (coming)
??? high 300's I hope
Modified by redturbocivic at 3:11 PM 4/3/2004
Walbro 255 intank
Injectors- RC 440cc
Fuel pump- walbro 255 intank
Fuel pressure regulator- b&m
Fuel pressure- around 43psi @ idle
What fuel management system you use- hondata stage 3 with all options
Hp(if you have dynoed or a guess)- ~280hp
Compression-
stock 10.2:1 until this winter
Injectors-
756cc (72# per hour)
Fuel pump-
holley 255lph
aem
Fuel pressure-
38psi
hondata s100 w/boost
248whp, @.65 bar. but I'm not exactly running .65 bar anymore, closer to 12psi
Injectors-
Fuel pump-
holley 255lph
aem
Fuel pressure-
38psi
Compression- 9.2:1
Injectors- 1000cc Precision
Fuel pump- Bosch
Fuel pressure regulator- Weldon
Fuel pressure- NA
What fuel management system you use- Autronic SMC
Hp(if you have dynoed or a guess)- No comment..
Fuel pump- Bosch
Fuel pressure- NA
H22a1 Stock compression, stock internals
Injectors- RC 550's
Fuel pump- Walbro 255 LPH
Fuel pressure regulator- Stock
Fuel pressure- Stock
What fuel management system you use- AEM EMS with AEM wideband
Hp(if you have dynoed or a guess)- 314 whp & 238 wtq @ 12 psi
Injectors- RC 550's
Re: Turbo people list your Fuel Management Setups HERE (tunedbylorange.com)
Compression- 9:1
Injectors- 880cc Precision
Fuel pump- Walbro 255lph
Fuel pressure regulator- B&M
Fuel pressure- 40psi
What fuel management system you use- AEM EMS w/ AEM UEGO
Hp(if you have dynoed or a guess)- 285WHP & 256TQ @12psi (Mustang Dyno)
Re: Turbo people list your Fuel Management Setups HERE (Alstare)
01 GSR
compression: Stock
Injectors: 580cc precision
fuel pump: walbro 255
fuel pressure reg.: stock
fuel pressure: ?
Management: Hondata s200, p72
HP: awaiting dyno tuning
compression: Stock
fuel pressure: ?
Re: Turbo people list your Fuel Management Setups HERE (mitsuman)
Compression- 9.8:1
Injectors- 720cc Lucas
Fuel pump- Walbro 255lph HP
Fuel pressure regulator- Stock with B&M
Fuel pressure- 38psi
What fuel management system you use- Hondata S200 w/ boost
Hp- See sig
Hp- See sig
Re: Turbo people list your Fuel Management Setups HERE (DC2R714)
well since i am returnless on my 2002 civic
modded vortec fmu with walbro fuel pump and factory fuel pump in tank...and safc2
converting to return fuel setup very soon
no dyno yet on 7lbs stock internals
Compression- stock d16y8
Injectors- stock
Fuel pressure- 60psi...crazy i know
Hp(if you have dynoed or a guess)- 160hp and 138tq @ 5 lbs
Injectors- stock
9.2:1 stock block b18b
~680cc injectors
Walbro 255lph
B&M FPR - Got an Aeromotive waiting to go in...
43 PSI
AEM EMS
240whp
~680cc injectors
Walbro 255lph
43 PSI
AEM EMS
240whp
Compression- 8.8:1cr
Injectors- RC 440's
Fuel pressure regulator- AEM
Fuel pressure- idle at 50psi
What fuel management system you use- AEM EMS with WB
Injectors- RC 440's
Re: Turbo people list your Fuel Management Setups HERE (9psiTurboSI)
9:5:1 copression b18c
Injectors-720cc
Fpr-b&m set at 42psi idle
pump-walboro 255
Hhondata s200b
est. 350whp at 12-13psi
Injectors-720cc
pump-walboro 255
Hhondata s200b
Compression- 10.6 (stock)
Injectors- precision 880
Fuel pressure regulator- stock
Fuel pressure- stock
What fuel management system you use- <U>Uberdata</U>
Hp(if you have dynoed or a guess)- 302whp 215tq @10psi
Re: Turbo people list your Fuel Management Setups HERE (ndogg)
Compression- STOCK D16Y7
Injectors- Lucus 440CC's
Fuel pressure- idle at 38
What fuel management system you use- Hondata S200 with Boost Option & 3 bar
EST HP 200whp 190TQ (IM SHOTTING FOR THIS @ 10 PSI)
ALL STOCK
ALL STOCK
Compression - Stock 9.2:1 - d16z6
Injectors - DSM 450cc w/resistor box
Fuel pump - Stock - walbro 255lph waiting to be installed
Fuel pressure regulator - Stock
Fuel pressure - Stock 42 psi
Fuel management - Uberdata
Dyno numbers - 216whp/181tq @ 10 psi
Total Price -
Total Price -
Re: Turbo people list your Fuel Management Setups HERE (evan2)
Compression- 9:1
Injectors- 1000cc
Fuel pressure- 43psi (at idle with line on)
What fuel management system you use- Hondata S200BD
Hp(if you have dynoed or a guess)- 536WHP & 375WTQ @26 psi (Dyno Jet)
also all stock fuel lines with a golden eagle fuel rail.
Injectors- 1000cc
Compression- 9.2:1
Injectors- 440cc RC injectors
Fuel pump- 255lpr walboro
Fuel pressure- NA
Hp(if you have dynoed or a guess)- close to 240hp
Fuel pressure- NA
