D16z6 rev capability?
Old Apr 1, 2004 | 07:32 PM
the jdmchop's Avatar
Default D16z6 rev capability?
on a fully built race motor whats my limitation to reving on a boosted Z6
i want to know how high is everyone reving too and if thats the limit that this motor can do?
Old Apr 1, 2004 | 07:40 PM
Default Re: D16z6 rev capability? (jdmchop)
bump for the night
Old Apr 2, 2004 | 06:08 AM
integracivic94's Avatar
bump cos i'd like to know too!
Old Apr 2, 2004 | 07:19 AM
RyanEJ8's Avatar
What is your definition of a "fully built" race motor?
Old Apr 2, 2004 | 08:09 AM
Default Re: D16z6 rev capability? (RyanCivic2000)
78mm sleeved block
ported head along with the nessasary componets for the valvetrain
T61 running on alky
Old Apr 2, 2004 | 08:12 AM
RyanEJ8's Avatar
8000-9000rpm depending on the cam and what valvetrain components you buy. You're going to need a nice set of rods and rod bolts too.
Old Apr 2, 2004 | 08:13 AM
ELSpool's Avatar
From what I've read, the issue of reving to high on a D-series becomes fast piston speed from the r/s ratio causing alot of stress on the walls and rods, and ZEX man had mentioned something about tranny gearing.
Old Apr 2, 2004 | 08:21 AM
Default Re: (ELSpool)
keep on coming
Old Apr 2, 2004 | 08:22 AM
RyanEJ8's Avatar
Default Re: (jdmchop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">keep on coming
Keep what coming, we just answered your question.
Old Apr 2, 2004 | 08:41 AM
Default Re: (RyanCivic2000)
keep any and all info retaining my question coming
knowledge is power
the more input i get the better
( not to say yours wasnt good )
but anyone with some exprience in reving a D high please add to the thread
Old Apr 2, 2004 | 08:45 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">From what I've read, the issue of reving to high on a D-series becomes fast piston speed from the r/s ratio causing alot of stress on the walls and rods, and ZEX man had mentioned something about tranny gearing. </TD></TR></TABLE>
Good reply. I plan on revving mine to 8000 without problems. Again, like Ryan said, you need a cam that can provide power to arond 8000. I think the consensus is the 59300 cam.
HTH
Old Apr 2, 2004 | 09:12 AM
Default Re: (ladysman)
who makes the best valve train for the D
Rocket makes a FI cam but i havent realy looked into that much
i would love to use his products seeing how his stuff isnt all mainstream and still preforms better than the others
Rocket can you help me out?
Old Apr 2, 2004 | 09:28 AM
5thgencivic's Avatar
Zex Man doesn't rev over 7000 on his even with the zex cam and valve spring setup(I think that's what I read?). Not sure if his head is ported though.
Old Apr 2, 2004 | 09:32 AM
Default Re: (5thgencivic)
only revs to 7k?
i would think these motors will make power past that no?
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">Zex Man doesn't rev over 7000 on his even with the zex cam and valve spring setup(I think that's what I read?). Not sure if his head is ported though.</TD></TR></TABLE>
His isn't done up as far as I remember. I think vavlesprings, that's it. He can jump in though and correct. me.
Turbodcx revs to 8500 I believe.
Old Apr 2, 2004 | 09:33 AM
Let me see if I can find his post, because I could be wrong...
wow this thread is flying lol
keep it up
more input from the racers
Old Apr 2, 2004 | 09:39 AM
kranked91dx's Avatar
no prob's up to 9K rpm
if you have:
balanced crankshaft and rotating assembly
acl crank bearing and rod glider bearing
good rod bolt and rod
spring, retainer, and of course a cam that can provide you with the need's of your engine up to 9000 rpm.
in other word, you need's to really want it to rev that high,
Kranked
Old Apr 2, 2004 | 09:45 AM
Default Re: (kranked91dx)
Here are some quotes from ZEX Man's replies in this post https://honda-tech.com/zerothread?id=718965
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZEX Man &raquo;</TD></TR><TR><TD CLASS="quote">
Cylinder Head:
D16Z6 SOHC V-TEC cyl. head (unported)
D16Z6 intake manifold (port matched)
Stock throttle body
ZEX™ valve springs (912-16)
ZEX™ camshaft (59300)
Performance distributor with MSD wires
I shift at 7200.......On the dyno, the engine makes peak power at 6900, so a little over that has proven to be the best for et's. FAST makes some very nice stuff, I really like their datalogger. I have learned a bunch about the car/engine since using it.
ZEX Man
With a ported head/intake manifold power should peak higher in the rpm range I would think.
Old Apr 2, 2004 | 09:50 AM
so zexman is running a basicly stock head minus the cam and springs!
i think with a better flowing head reving high will be atainable
Old Apr 2, 2004 | 11:12 AM
blackeg's Avatar
wow i would think that the 53900 in his engine would make his peak power over 7000 rpm's. stock peak hp is at 6600, as i found out first hand when i dyno'ed.
Old Apr 3, 2004 | 07:10 AM
M.A.R.C.'s Avatar
Default Re: (blackeg)
not to jack the thread but what u guys think would be a good rev limit for my setup...
2000 D16Y8 head
Crower springs and retainers
Zex 105300 cam (the Y8 version of the Zex Z6 Street/Strip cam)
turbo is a precision SC61 (stage 5 turbine wheel)
the bottom end is a Z6 with 9:1 JE's and Eagle rods but with the y8 the cr should be like 9.5:1 or so. My guess is 8000-8200 rpm would be safe
boosted97civic
Dec 19, 2007 02:58 PM
Br1anPham
24
Nov 15, 2004 09:24 PM
static_signal
Jan 22, 2004 05:37 PM
