B20 or LS??
Old Apr 3, 2004 | 07:44 PM
phatboy's Avatar
Default B20 or LS??
I have to choose between these 2 motors...I want to turbo the motor after a couple a months..i want to know which one can hold more boost? The block is going to be all stock and the head is goin to be built a little with valves cams and port n polish...so wut is better?
Old Apr 3, 2004 | 08:06 PM
DXK Eg's Avatar
Default Re: B20 or LS?? (phatboy)
i would go with the LS block, the sleeves are a bit thicker than the b20 it can and will take up to 12 pounds of boost but if you get on with low miles and in good con. and it's cheaper. but this is just me it could go away way.
Old Apr 3, 2004 | 11:21 PM
mskibbz-T's Avatar
Default Re: B20 or LS?? (dynasty-x-motorsport)
B18B no question
Old Apr 4, 2004 | 01:26 AM
EXOSPEED:SHARK's Avatar
From: Azusa,CA USA/ Manila Land of the Pick Pockets
Default Re: B20 or LS?? (mskibbz-T)
ls motors have thicker sleeves than a b20...its a 9mm as opposed to the b20's flimsy 7mm. but dont expect that b20 to last long because those sleeves will crack. do a search on b20 turbos. youll find the alot of people are doing the same thing wrong when turbocharging a bone stock b20. ls will definitely hold up longer than the b20. hope this helps
Old Apr 4, 2004 | 03:16 AM
TurboTony's Avatar
Default Re: B20 or LS?? (SCHIKANEdc4)
LS
Old Apr 4, 2004 | 03:28 AM
97ITR60's Avatar
Default Re: B20 or LS?? (TurboTony)
just like everyone else i say to go with the b18b. they hold more boost with the stock bottom end and are a very good engine, especially when the bottom end is built. get the b18b now and build the bottom end later.
Old Apr 4, 2004 | 05:28 AM
mskibbz-T's Avatar
Default Re: B20 or LS?? (97ITR60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ITR60 &raquo;</TD></TR><TR><TD CLASS="quote">just like everyone else i say to go with the b18b. they hold more boost with the stock bottom end and are a very good engine, especially when the bottom end is built. get the b18b now and build the bottom end later. </TD></TR></TABLE>
If a B18B is fully built and sleeved it would be the same as a fully built and sleeved B20B
Old Apr 10, 2004 | 05:46 AM
13link EG's Avatar
b18b can hold mad boost for stock but the b20 can also, i would say b20 is better for vtec
Old Apr 10, 2004 | 05:50 AM
loud_whispers's Avatar
Default Re: (13link EG)
b20 = weak walls.
b18b bored to 2L = stronger b20 block
LS!
Old Apr 10, 2004 | 06:09 AM
showtymers619's Avatar
* B A N N E D *
Default Re: (loud_whispers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loud_whispers &raquo;</TD></TR><TR><TD CLASS="quote">b20 = weak walls.
LS!</TD></TR></TABLE>
wrong fyi becomes just as brittle
Old Apr 10, 2004 | 08:26 AM
Ri5e's Avatar
LOL...Maybe if you sleeved the LS first.
I've had the B20 and the LS. B20 isn't worth it unless you are running conservative and low amounts of boost
Old Apr 10, 2004 | 10:54 AM
00siBuilder's Avatar
Default Re: (BG Boost)
b20 for daily driver something fun to drive around town.
B18b for drag
Old Apr 10, 2004 | 11:25 AM
blueturbo4door's Avatar
Default Re: (00siBuilder)
just boost the b18, you will lose a little torque but it will be worth it to be safe, just make sure you are tuned good
93h2beg
Feb 12, 2013 12:16 PM
sohc-ek4
Jun 8, 2009 12:14 PM
2ndgentegracer
Aug 11, 2006 03:16 PM
who00knows
Feb 20, 2003 02:18 PM
TenaciousC
Nov 14, 2002 02:47 AM
