the hack 270 RC injectors
Old Apr 1, 2004 | 05:09 AM
xxthabest1xx's Avatar
Default the hack 270 RC injectors
can i run the hack with 270cc rc injectors. I been had them and want to use them till i get more money for bigger one and hondata. Does anyone have setting for this if it can be done I would appreciate it. I have missing link and fmu I know I wont need if i run the hack but what do you think. ON a b18c
Old Apr 1, 2004 | 05:16 AM
showtymers619's Avatar
* B A N N E D *
Default Re: the hack 270 RC injectors (xxthabest1xx)
thats barely any room to do any adjustments...you might need to still use the FMU with it...
heres what liam gave me
(b - a) / a = c , where a = orginal injector size, b = new injector size, and c = percentage larger.
ie
(450 - 240) / 240 = 0.875, 87% larger
To find value needed for the afc you use the same formula..only swap around the injector sizes..
(240 - 450) / 450 = -0.4666 or -46% (although id add 10% on top of that to keep the honda happy under boost)
thats to get to the stock injector size flow...
Old Apr 1, 2004 | 05:32 AM
Default Re: the hack 270 RC injectors (ShowTymers619)
Ok my fmu is a 10.1. what do you think. I need help with this im stupid
Old Apr 1, 2004 | 06:15 AM
* B A N N E D *
i say get the stock setting as close as you can with the injectors... then add 5% all around and have the FMU do its work...it also depends how much your gonna boost...
Old Apr 1, 2004 | 06:25 AM
pollito's Avatar
270cc RC injectors would be good for no more than a few pounds of boost using the straight up AFC hack. The cusion those injectors create is much smaller than the 440s.
Old Apr 1, 2004 | 06:39 AM
b16ahybrid's Avatar
Default Re: (pollito)
At 270cc your ecu will compensate for the "would be" extra fuel.
I would recomend running a fmu with the afc, use a 10:1 fmu and the afc to fine tune the fuel curve. Otherwise you can run 2psi or so with the 270cc injectors. 240 is stock so 270's areonly about 15% larger
Old Apr 1, 2004 | 06:47 AM
Default Re: (b16ahybrid)
so how much boost would be alright with the 10.1 fmu and the 270's. i just need it to get me by a couple of days.
Old Apr 1, 2004 | 06:56 AM
* B A N N E D *
Default Re: (xxthabest1xx)
i would say that prolly good for 7 psi at the most.... its prolly almost close to 310cc .. but thats pushing the injectors
Old Apr 1, 2004 | 07:00 AM
Default Re: (ShowTymers619)
THANKS GUYS YA BEEN HELPFUL
Old Apr 1, 2004 | 08:06 AM
kpt4321's Avatar
Without a FMU, you need at least 440-450cc/min injectors to properly run the hack. Since you can't run any bigger than 500 cc/min (SAFC limitation), 440's or 450's are really your only choice.
With a FMU, you can run any dinky little injectors you want.
HiProfile
Dec 23, 2006 06:57 AM
dbwsi
Aug 17, 2005 05:03 AM
tspkenneth
Feb 20, 2005 07:15 AM
Layziebtnh055
Oct 9, 2004 03:48 PM
StrangerWitCandy
Jul 2, 2004 09:04 PM
