Static timing with afc hack
Old Apr 1, 2004 | 10:39 PM
jetpilot's Avatar
Default Static timing with afc hack
where should I set my stock timing for the afc hack (at the dizzy i mean)? I wont be using an msd 6btm just straight up injectors and afc to -40%. 10psi will be the max I ever boost, normaly it will be 6psi
Old Apr 2, 2004 | 07:38 AM
jetpilot's Avatar
I know it may have been covered quite a few times but I dont know under what to search for it that brings me back any positive results
Old Apr 4, 2004 | 06:24 PM
jetpilot's Avatar
up
somebody please
Old Apr 4, 2004 | 08:14 PM
pollito's Avatar
It really depends on the car but I would say about 4* taken out.
Old Apr 5, 2004 | 04:34 AM
jetpilot's Avatar
So I should set the timing at 12* btdc.
How about if I use an FMU setup? This is for a friend whos finishing his ghetto turbo as weel but not using the afc hack
Old Apr 5, 2004 | 08:17 AM
Joseph Davis's Avatar
Default Re: (jetpilot)
AFC hack advances timing at WOT NA and at low boost. You ideally want to retard your timing 2-3 degrees (listen/read plugs/etc for knock) and run as much as the Honda MAP sensor can handle. Setting boost levels at 8-9.25 psi OBD0 and 8-10.65 psi OBD1+ will keep you from operating for extended periods of time (95% of your boosting) in the areas of high ignition advance. I also do not recommend an MSD or a BTM for an AFC hack - MSD is useless until you appraoch 400 whp, and a BTM does nothing to correct the ignition timing problem associated with AFC hacks.
As far as FMU, since they aren't dependable in high ratio/small injector setups past, say, 6 psi I wouldn't bother with a BTM. Your friend needs to step up to something else entirely if he wants more power.
Old Apr 5, 2004 | 11:01 AM
99lspwr's Avatar
Default Re: (J. Davis)
I know for a fact the btm DOES take out timing under boost while using the afc hack....How much timing, well lets just say I dont think they are to accurate...
I use one for running 13-14 psi on pump gas w/ no problems...Not saying its the best way to tune, but the btm does indeed take timing out when you use it with the afc..
twkdCD595
Feb 14, 2004 11:48 AM
SOFLSOL
Sep 11, 2003 09:17 AM
asianspeed
Aug 8, 2003 05:05 AM
BorderM3
Dec 30, 2002 11:40 AM
kidkutz
Jun 25, 2002 01:34 PM
