What size injectors for my turbo setup??
Old 03-31-2004, 11:49 AM
xtremeness101's Avatar
Default What size injectors for my turbo setup??
Here is my setup im putting together:
b18c1
stock bottom
stock head
Garret t3 60 trim a/r .48
tial wastegate
tial 50mm BOV
spearco intercooler
2.5" downpipe
3" catback
hondata with boost option and datalogging
I will be running 8-9 psi daily driven.
My question is; What kind of injectors and what size what you reccomend me getting. What else would i need in regards to my fuel system. Fuel pump? Fuel rail? Fuel Pressure regulator? What sizes and brands do you recommend?
Thanks in advance for any help you guys can give me.
Old 03-31-2004, 11:59 AM
MaxSterling's Avatar
Default Re: What size injectors for my turbo setup?? (xtremeness101)
440cc, stock fpr 1:1.
Old 03-31-2004, 12:19 PM
Default Re: What size injectors for my turbo setup?? (MaxSterling)
what should i get 440 rc injectors? or is there a different kind i should get?
also what does saturated injectors mean?
Old 03-31-2004, 12:33 PM
99B16Si's Avatar
saturated dont require a resistor box. id go with 550's just to leave yourself with some room later on down the road.
Old 03-31-2004, 12:36 PM
VisualAutoMotoring's Avatar
Default Re: (99B16Si)
If u plan on boostin more later, then go with
550cc now
fuel rail
aeromotive FPR
Walbro 255
remember fuel is very important...better to have more and run a lil rich then u can always tweak it down
Old 03-31-2004, 12:38 PM
TravSi's Avatar
i would go with 550's (RC), 255 pump (Walbro), and adjustable fpr....Since yur running a Hondata it will run good with 550's....
Old 03-31-2004, 02:23 PM
civic97dx's Avatar
Default Re: What size injectors for my turbo setup?? (TravSi)
go with 550cc's
I'm going with a similar set-up and my tuner recommend thoses. Leaves more room for upgrades
Old 03-31-2004, 02:31 PM
ladysman's Avatar
Default Re: What size injectors for my turbo setup?? (civic97dx)
I agree with the 550cc recommendation.
Old 03-31-2004, 07:21 PM
Default Re: What size injectors for my turbo setup?? (ladysman)
Thanks, im going to go with the 550s
Old 03-31-2004, 07:23 PM
Timmay's Avatar
dsm's would work good for under 10psi
Old 03-31-2004, 07:32 PM
D3LSLO's Avatar
Default Re: What size injectors for my turbo setup?? (Timmay)
the stock fuel rail will handle quite a bit, up to 300-350 i believe, someone correct me, but based on ur set up i think that will be fine for u, ma7ybe get a fpr and do go with those 550s.
golf-mk3
10-07-2010 05:27 AM
B6teen
01-08-2008 07:46 PM
prelude1911
05-20-2005 08:37 PM
buda18
11-10-2003 06:46 PM
Hybridhonda10
04-03-2002 07:39 AM
Quick Reply: What size injectors for my turbo setup??
