Problems, built new motor!
Old Apr 2, 2004 | 01:17 PM
reditr's Avatar
Default Problems, built new motor!
Hi guys
I have just finished building up my motor and started up. After doing 50 kilometers, i have decided to check my plugs, i ve noticed that on piston no:4 there was oil on the surface of the piston, and a very dark black glaze on the plug. I have changed the valves ,springs +retainers but did not change the valve seals.
I have tried a compresion test , and everything seems to be ok , 195 PSI on each cylinder inc no:4.
As regards i have noticed that it s blowing some white smoke from the exhaust, but very minor, when i push the car till 5500rpm on boost.
Can somebody help me pls in this prob, cause i m very fed up with my motor.
It s been a year since i ve been trying to boost this motor up! since then i have never had a positive experience!
Old Apr 2, 2004 | 01:31 PM
Flr Power's Avatar
Default Re: Problems, built new motor! (reditr)
You must be running too rich. Do you have a WB o2 meter? If not, get one.
Old Apr 2, 2004 | 01:48 PM
birz's Avatar
Default Re: Problems, built new motor! (coocoo32)
white smoke usually equal head gasket failure
Old Apr 2, 2004 | 01:59 PM
omahaturbocivic's Avatar
Default Re: Problems, built new motor! (birz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birz &raquo;</TD></TR><TR><TD CLASS="quote">white smoke usually equal head gasket failure </TD></TR></TABLE>
I have also noticed that oil can cause a white looking smoke when it is not acutally burned in the cylinder but cooking in the exhaust system. I have seen several cars with bad turbo seals on the exhaust side that smoked white smoke however if it would have been on the intake side and the oil was actually burned in the cylinder it would look blue. My prediction is valve seals, the white smoke may be oil leaking out the exhaust seals and into the exhaust system. The oil in the cylinder is of course the intake seals leaking. When the head was off was it cleaned in a parts washer or anything like that? If so it probably ruined the seals and they should have been replaced after that.
Old Apr 2, 2004 | 02:20 PM
Hoosier Daddy's Avatar
Quite possibly the dumbest response anyone could have made. Let's go and scare him by saying his head gasket is bad, even though his compression is perfect
Cylinder #4 may be running a little bit more rich than the other for some reason. I wouldn't worry about it. Get it tuned and you'll most likely be good to go
What are you using for fuel management?
Modified by Hoosier Daddy at 9:04 PM 4/2/2004
Old Apr 2, 2004 | 04:40 PM
Flr Power's Avatar
Default Re: Problems, built new motor! (Hoosier Daddy)
Still the head will have to come off. So Birz is not that far off. Just go fo a beer...
Old Apr 2, 2004 | 04:43 PM
FredoSP's Avatar
I hope your not breaking in the motor this rich, there's a possibility you COULD wash away your rings if you have too much fuel - Just something to consider.
Old Apr 2, 2004 | 04:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coocoo32 &raquo;</TD></TR><TR><TD CLASS="quote">Still the head will have to come off. So Birz is not that far off. Just go fo a beer...</TD></TR></TABLE>
Why? The compression is perfect, he has nothing to worry about. Who takes apart motors with perfect compression?
danl's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">
Cylinder #4 may be running a little bit more rich than the other for some reason. I wouldn't worry about it. Get it tuned and you'll most likely be good to go </TD></TR></TABLE>
You can have a bad HG and good compression test. I've done it!
Old Apr 2, 2004 | 04:56 PM
Default Re: Problems, built new motor! (danl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danl &raquo;</TD></TR><TR><TD CLASS="quote">
You can have a bad HG and good compression test. I've done it!</TD></TR></TABLE>
I'm sure there were a lot more symptoms than "a little bit of white smoke from the tailpipe" though. To come to the conclusion that the head gasket is bad because of a little white smoke is preposterous.
Old Apr 2, 2004 | 05:21 PM
Flr Power's Avatar
Ok, so what's your call then?
Old Apr 2, 2004 | 05:53 PM
psileepR's Avatar
New User
Default Re: Problems, built new motor! (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">I hope your not breaking in the motor this rich, there's a possibility you COULD wash away your rings if you have too much fuel - Just something to consider.</TD></TR></TABLE>
i second this theory that you washed cylinder number 4 somehow. Especially since u see oil in that cylinder.
Old Apr 2, 2004 | 06:10 PM
lazerus's Avatar
compression doesen't have to be low to have a blown head gasket, or a warped mating surface.
Modified by Hoosier Daddy at 9:04 PM 4/2/2004</TD></TR></TABLE>
Old Apr 3, 2004 | 06:35 AM
mchuang's Avatar
If you didnt change the valve seals on your head they could be leaking also. Just check for lots of white smoke out of exhaust.
Old Apr 3, 2004 | 08:04 AM
Flr Power's Avatar
Time for new valve seals.
4dek
Jun 4, 2008 07:51 PM
kikwear002
Jan 24, 2005 06:09 PM
newBcrxer
Aug 27, 2004 08:00 AM
QuickHonda
Aug 9, 2001 12:54 PM
