Compression question JDM B16
Old Apr 1, 2004 | 12:13 PM
hair_rice's Avatar
Default Compression question JDM B16
aalright i just got my leakdown test done and t came up with 240 across the board...now what kind of compression am i looking at? i wanna eventuall just through my b16 greddy turbo kit in but if the compression is to high i assume i will change out the pistons with low comps...please any info pertaining to this topic is greatly appreciated
BTW it is a jdm B16 sir2 with a pnp work....gsr cams..runin the si ecu
Old Apr 1, 2004 | 12:38 PM
hypa's Avatar
FYI, I comp tested my jdm b16 block with usdm GSR head, and hit 225 across the board.
As for compression during a comp test, and compression ratio, I think you're confused. Comp ratio is something related to, yet different from your compression test results.
Old Apr 1, 2004 | 12:41 PM
keebler65's Avatar
Default Re: (hypa)
a compression test of 240 indicates a very healthy motor. your compression ratio on the B16A is 10.2:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote">FYI, I comp tested my jdm b16 block with usdm GSR head, and hit 225 across the board.</TD></TR></TABLE>
not to get off topic but what is your compression ratio with that setup?
Old Apr 1, 2004 | 12:53 PM
hair_rice's Avatar
Default Re: (keebler65)
so would runnin a greddy kit be a problem at the stock spring setting which i think is either 6 psi or7 psi? i saw they are using emanage in some apps...how do you guys like emanage for low boost?
Old Apr 1, 2004 | 01:03 PM
hypa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 &raquo;</TD></TR><TR><TD CLASS="quote">not to get off topic but what is your compression ratio with that setup?</TD></TR></TABLE>
As per the c-speed compression calculator, I should be in the 10.6:1 range. Scary stuff when I'm pushing 9psi of uncooled jrsc air into the motor.
I guess I'm not a bad tuner afterall.
hair_rice, As long as you're tuned properly, you'll be fine with the Greddy kit. I recommend going with a J&S or some other knock sensor system as a safety net, and remember, good gas will save your ***!
Old Apr 1, 2004 | 01:16 PM
hair_rice's Avatar
Default Re: (hypa)
thanks for the info...but what is safety net...never heard of it
Old Apr 2, 2004 | 01:10 PM
hypa's Avatar
Default Re: (hair_rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hair_rice &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info...but what is safety net...never heard of it</TD></TR></TABLE>
A safety net is nothing more than a term.
Basically my point was that if it's tuned well, you'll have no problems.\
JDMCIVIC919
Nov 6, 2011 11:46 PM
crxfreak1117
Oct 13, 2006 12:22 PM
davidcrx89
Jun 26, 2005 10:52 PM
mustbenu
Jan 23, 2004 12:56 PM
Rob!
Sep 22, 2002 05:34 PM
