GASKET SEALER?
Old Apr 3, 2004 | 10:13 PM
kabaroo's Avatar
Default GASKET SEALER?
im putting my mani back on my turbo soon. is there any sealer i should put between the manifold and the turbo? its a greddy kit. also there isnt a gasket is that a problem?
Old Apr 3, 2004 | 10:25 PM
gritsak's Avatar
Default Re: GASKET SEALER? (kabaroo)
your suppose to have a gasket
Old Apr 3, 2004 | 10:36 PM
VNTEC's Avatar
B A N N E D
Default Re: GASKET SEALER? (gritsak)
Not really, some people run with no gaskets at all with no problems...
VNTEC's Avatar
B A N N E D
Default Re: GASKET SEALER? (VNTEC)
Btw as far as i know, there is no type of sealer that can withstand the heat of where u wanna use the sealer.. only gaskets would work
Old Apr 3, 2004 | 10:41 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VNTEC &raquo;</TD></TR><TR><TD CLASS="quote">Not really, some people run with no gaskets at all with no problems...</TD></TR></TABLE>
yeah and some people run an afc hack with no problems either
im just saying that you are suppose to have a gasket..if you dont have one and the surfaces arent perfectly flat then you are gonna have an exhaust leak at one of the last place you want it..right before the turbo. if you cant get a gasket ide check to make sure they are flat, or spend the extra money and go get the surfaces machined
Old Apr 3, 2004 | 10:50 PM
kabaroo's Avatar
Arg, the closer i get to installing this kit the more incomplete it is! anyone else? your sure there is no sealer of anykind?
Old Apr 4, 2004 | 12:31 AM
lazerus's Avatar
permatex indian head sealer..
or no gasket
Old Apr 4, 2004 | 01:29 AM
kabaroo's Avatar
Default Re: GASKET SEALER? (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">permatex indian head sealer..
or no gasket </TD></TR></TABLE>
Thank you !
Old Apr 4, 2004 | 03:36 AM
J337_UNIT's Avatar
...or copper silicone
Old Apr 6, 2004 | 09:52 AM
kabaroo's Avatar
Default Re: GASKET SEALER? (J337_UNIT)
up
Old Apr 6, 2004 | 10:14 AM
Egg-weezy's Avatar
There is a copper silicone gasket maker that can with stand up to about 1200 degrees. In my setup i used the gasket and the gasket maker to get a really good seal. I wouldn't run without a gasket if i were you. It doesn't create a perfect seal and you could get a leak in you system.
Old Apr 6, 2004 | 10:19 AM
Trac226's Avatar
Default Re: GASKET SEALER? (dainteg)
Greddy kit has a gasket between manifold and turbo. It never leaked on me when I had the kit (w/gasket). But, guess you can always try without one and let us know how it goes . It should be okay, the surfaces were machined.
Old Apr 6, 2004 | 10:25 AM
Egg-weezy's Avatar
Default Re: GASKET SEALER? (Trac226)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trac226 &raquo;</TD></TR><TR><TD CLASS="quote">Greddy kit has a gasket between manifold and turbo. It never leaked on me when I had the kit (w/gasket). But, guess you can always try without one and let us know how it goes . It should be okay, the surfaces were machined.</TD></TR></TABLE>
Just to let you know when you have two metal surfaces in an engine bay rubbing against each other that get past the 1000 degrees marker you have expanding and contracting metals that moves depending on temp. Your engine torques back and fourth all the time when you beat on it and the exsaust is always moving to. Most likely you're gonna get some kind of leak. I'd just go to the store and by a gasket for 12 bucks instead of putting it all back together and finding out that you can't boost right because of a leak in you ****. But hey, thats my opinion and you don't have to do what i think if you don't want to.
EDIT: put it this way would you run without a head gasket. your head and block were also "machined"
Old Apr 6, 2004 | 10:35 AM
TravSi's Avatar
I agree just put a gasket on it, no need to be a pioneer.....Just do what has been done since cars were first made, You can get a metal gasket from honda for 14 bucks, shouldnt break yur wallet to bad
Gaskets
Old Apr 6, 2004 | 11:56 AM
turboteg96's Avatar
Default Re: GASKET SEALER? (TravSi)
Ive been using this stuff
http://www.rmoreau.com/mms3500.htm
So far, so good. Mind you, its only been 2 days...
Old Apr 6, 2004 | 01:12 PM
kabaroo's Avatar
Default Re: GASKET SEALER? (turboteg96)
only reason i dont want to buy a gasket is cuz i dont know where to get one. my manifold and turbo didnt come with one... i bought it used. i just had my manifold sand blasted by a friend.
After sandblasting i noticed a small crack in the mani. its inside so the blasting cleared all the carbon build up so i could see the crack. yay another problem. i swear i got the greddy kit from hell.
anyone know where i can get a gasket... i dont care about the $$ i want it done right.
Old Apr 6, 2004 | 08:20 PM
kabaroo's Avatar
up
Old Apr 6, 2004 | 08:25 PM
gritsak's Avatar
Default Re: (kabaroo)
maybe a greddy dealer, or a company that deals with alot of turbos....you could also try and find out what, if any other turbos will bolt onto the greddy manifold and find a car that comes stock with a turbo that shares the same exhaust flange and go to a dealer and get a gasket.
they do make a sheet of make your own gasket for some applications, mostly like for water/oil. im not sure if they make anything thats high temp that you can cut your own gasket from but you can look online
Old Apr 6, 2004 | 08:45 PM
isuhonda83's Avatar
I used permatex ultra copper in between the pieces of a two piece header and it held up for a while, but given a couple months it had been affected by the heat and went bad. I am sure the same thing would happen on a turbo, maybe even faster.
Old Apr 6, 2004 | 10:03 PM
rtype11's Avatar
if you need a gasket casue the surfaces dont mate perfectly flush head down to a ford dealer and ask for a SVO stang or TB turbo gasket. like $3.50
Old Apr 6, 2004 | 10:53 PM
kabaroo's Avatar
Default Re: GASKET SEALER? (rtype11)
http://www.prostreetonline.com...A-004
will this gasket for my td04 ?
Old Apr 7, 2004 | 12:03 AM
Group Tenacity's Avatar
I went to NAPA and got a sheet of gasket material used for the turbo gaskets on Ford turbo desils. Its a ceramic/metal type gasket material and has to be cut to your application using sheet metal sheers or a dremel. Kind of difficult to cut since you cant bend it or the ceramic will crack and make it useless, but a dremel should get the job done without bending it..
hope that helps..
Mike...
Old Apr 7, 2004 | 07:31 AM
kabaroo's Avatar
Default Re: GASKET SEALER? (Group Tenacity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group Tenacity &raquo;</TD></TR><TR><TD CLASS="quote">I went to NAPA and got a sheet of gasket material used for the turbo gaskets on Ford turbo desils. Its a ceramic/metal type gasket material and has to be cut to your application using sheet metal sheers or a dremel. Kind of difficult to cut since you cant bend it or the ceramic will crack and make it useless, but a dremel should get the job done without bending it..
hope that helps..
Mike...</TD></TR></TABLE>
thanks man, i check out some of the general auto part stores today
Old Apr 7, 2004 | 07:36 AM
showtymers619's Avatar
* B A N N E D *
jb weld
Old Apr 7, 2004 | 10:24 AM
Egg-weezy's Avatar
Default Re: GASKET SEALER? (ShowTymers619)
Eeeek!! Your turbo manifold has a crack in it?? hopefully you didn't pay that much for the turbo kit..... Even if its a small crack you could have a leak that you can't see.
