Pics/Info---DA Traction Bars from Z10
The Traction bar kits for the 90-93 integra will be available to the public in less than 2 weeks. Wanted to give everyone a heads up and some info regarding the bars. I was chosen to test the prototype set and give feedback to Z10. Mind you that I feel obligated to share any and all info on these bars with H-T regardless of wether it is good or bad.
Even though the DA's are equipped with a factory radius rod setup, wheel hop is still an issue in these cars. I lost a couple of diffs/cases to this problem especially when on the 24.5's. Since the Z10 bars were put on, wheel hop has COMPLETELY stopped. The ground clearance is way better than stock, the crossmember doesnt sit nearly as low as the stocker. Before, I had to cut the **** outta my oem member to allow clearance for the JDM R header. Now I have 2 3/4in of clearance where before there was only 1/4in. This setup will clear a 3in downpipe easily as well as a big header.
The front trans mount is retained and is nice and easy to work with. The setup uses two heim joints for easy caster adjustment while still on the car. This would definitely be beneficial to those road racers out there, who frequent different tracks. Havent hit a well prepped track yet, but on the street the car dead hooks. Im hoping for high 1.5 60's with this setup...If anyone has any questions regarding the bars, feel free to IM me or contact Z10 @ 732-922-2309. The price is 450 shipped and powdercoated. They do offer the bars without powdercoat for a reduced price. Okay, enough talkin here are pics....
Re: Pics/Info---DA Traction Bars from Z10 (quickda6)
crossmember
Full kit
Close ups
Here is a link to pictures of the setup on my car....
http://www.imagestation.com/album/?id=4287430495
Full kit
Close ups
Re: Pics/Info---DA Traction Bars from Z10 (g2turbo)
damn!! that looks nice.....
My crossmember has a big hole with a plate welded in and the DP still hits
Re: Pics/Info---DA Traction Bars from Z10 (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 »</TD></TR><TR><TD CLASS="quote">
My crossmember has a big hole with a plate welded in and the DP still hits </TD></TR></TABLE>
hahah, ive been there....
sh!t happens.
Re: Pics/Info---DA Traction Bars from Z10 (VNTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VNTEC »</TD></TR><TR><TD CLASS="quote">Hey any word on the ABS modulator? I wanna keep my ABS while using this radius bar</TD></TR></TABLE>
?????????????? whats that mean u cant keep abs with that setup?
that traction bar kit is sooo badass........
Re: Pics/Info---DA Traction Bars from Z10 (G"UNIT)
What i meant was... If u had a DA that has ABS, you'd notice you have a ABS Modulator that is supported by the stock cross member... With this traction bar there is no place to put it..
Im aware, I used to have a GS. I figured the could machine a bracket for the right side that would still allow for its use.
