LS/ Turbo Street buildup help
was wondering if you guys can give me some advice on wat i should get for my daily driver ls/ turbo im gonna b running 8psi wat cams should i get and intake monifold should i leave my bottom end stock?wat size injectors an throttlebody an wat i should degree my cams to an wat fuel pressure tell me wat u think the best set up should b thankss
Re: LS/ Turbo Street buildup help (skip122)
It all depends how much power your aming for.
You want 250, 300, 350 HP. How much money do you want to spend and so on...
Try searching around, there are milion questions in the archive just like this.
, all the best of luck on you project.
/PH
/PH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skip122 »</TD></TR><TR><TD CLASS="quote"> was wondering if you guys can give me some advice on wat i should get for my daily driver ls/ turbo im gonna b running 8psi wat cams should i get and intake monifold should i leave my bottom end stock?wat size injectors an throttlebody an wat i should degree my cams to an wat fuel pressure tell me wat u think the best set up should b thankss
so basically u want to know exactly what to do to turbo your car? try searching LS turbo is not a new topic.
skip122
04-03-2004 05:18 PM
