When to Upgrade Ignition ?
Old Apr 2, 2004 | 06:16 PM
92HB_HB's Avatar
Default When to Upgrade Ignition ?
at what HP pt should you plan to upgrade your stock honda ignition.. ie, add a blaster/external coil.. and how hard is it to do?? i'm only askin cuz i've never done it yet..
thanks..
Old Apr 7, 2004 | 03:50 PM
Charlie Moua's Avatar
Default Re: When to Upgrade Ignition ? (92HB_HB)
well honda's come with excellent factory ingintion system.
Stock for stock, it should be able to handle about 350 to 400whp. BUT if I was making more than 300whp I would feel safer with MSD 6al and some sort of blaster coil.
if your planning on keeping the ignition simple and stock just make sure all parts are in prestine order such as a fresh cap & decent plugs, also check to make sure your OEM spark plug wires are not too old and crudy...
ingiton should be one of the last things you need to upgrade if your under 300whp.
HTH
nowidriveacivic
Engine Management and Tuning
17
Aug 5, 2010 09:29 AM
bobbyeg6
Feb 21, 2010 12:44 PM
JDM_COUPE94
15
May 3, 2007 03:05 PM
SiRkid
Dec 15, 2006 10:53 AM
OMG WTF
Nov 15, 2006 10:29 AM
