final build plan
Old Mar 31, 2004 | 08:19 PM
zm_dawg's Avatar
Default final build plan
I believe after reading archive after archive and Mr. Bells book, I'm almost ready to stick the plan in stone.
EG H/b-OBD2 B18c1
Block-built by Earl
Benson Sleeved 84mm
CP Pistons 9.7:1 C/R
Pauter Rods
ACL Bearings
New Pumps
Crank balance/polish
block balanced
Stock Head
Upgraded springs & retainers...!?!
Turbo-
Precision SC34....still debating .48/.63...how big of a difference between max boost
IP Manifold
Tial 38mm
Precision 600HP IC or PWR 24x8
Blitz DC gauges/boost controller/BOV
2.5 IC Piping
3" DP/Cat./Exhaust/N1 Muffer - KTeller?
Oil Lines/Fittings- !?!
Engine Mgmt.
Hondata s200b
OBD2-1 Harness
GM 3 Bar Map sensor
Suspension...unsure...Koni/GC...not totally set yet
Please rip this apart....Any predetermined fitment problems....IC or Exhaust piping....ummm....i'm lookin like 275-325hp daily driver...like to be able to turn it up maybe around 400hp at the track...this is my first time and any help is great. I'd also like to thank everyone for their help, i've learned a lot lately, what to look forward to and what not to.
TIA
zach
Old Apr 1, 2004 | 02:51 PM
zm_dawg's Avatar
bump
also....tuners in the MidWest....i'm up in WI...anyone dealt with anyone around here and have some input to help me plan.
Old Apr 1, 2004 | 02:55 PM
JDcompman's Avatar
Default Re: final build plan (zm_dawg)
Looks good. Only thing I would suggest is going with OEM honda bearings instead of the ACLs. Good question on tuning though. I'm from the midwest, SD and I'm looking for someone as well for when i get my s200b. Looks good though man.
Old Apr 1, 2004 | 08:12 PM
00siBuilder's Avatar
Default Re: final build plan (JDcompman)
Fantasy build.. start ordering stuff.
Old Apr 1, 2004 | 08:19 PM
Smashback's Avatar
What would make you shy away from ACL bearings?
Old Apr 1, 2004 | 08:36 PM
zm_dawg's Avatar
why the issue w/ the ACL's?
Old Apr 1, 2004 | 08:53 PM
zm_dawg's Avatar
Default Re: final build plan (00siBuilder)
this isn't fantasy....awaiting insurance settlement check......trying to have this planned out as much as possible so I don't fall into many holes while during the install.....also I believe I'd need 550cc injectors..Precision/RC?!?..umm..should I do the whole 3"exhaust like that?...
Old Apr 1, 2004 | 10:07 PM
IntegracinGSR's Avatar
Alot of people just prefer to run the OEM honda bearing over the ACL's, i too will be using OEM bearing on my b-series build.. and i think you should do your 3" exhaust like that, it will be a little weaker on the bottom end but spool times will be quicker and so will max power in most cases.. but its up to you.. Good luck getting that check, insurance sucks, they just ripped me off over 10k in parts from my GSR that was stolen
Old Apr 2, 2004 | 06:34 AM
zm_dawg's Avatar
tks man...it's from an accident I was in w/ someone....what are more decent cat's?!? never looked around at aftermarket cat.
Old Apr 2, 2004 | 07:08 AM
JDcompman's Avatar
Default Re: (zm_dawg)
I've heard too many bad things about ACL's. Stick with the best, OEM. They should work just fine.
Old Apr 2, 2004 | 08:15 AM
Smashback's Avatar
Default Re: (JDcompman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDcompman &raquo;</TD></TR><TR><TD CLASS="quote">I've heard too many bad things about ACL's. Stick with the best, OEM. They should work just fine.</TD></TR></TABLE>
That's what I thought 90% of the info post here is hearsay. Probably another 8% is people that just don't know how to assemble an engine. I really doubt there is anything wrong with ACL.
How many people do you know what had problems with something (ACL in this case) more than once, and it wasn't their first time building an engine.
Old Apr 2, 2004 | 01:30 PM
zm_dawg's Avatar
yeah I'm confused about this whole ACL theory.....I don't think earl would have suggested'em if he strongly believes OEM are "better" then the ACL's....it just doesn't make sense
Old Apr 2, 2004 | 04:12 PM
Sunrise City Rider's Avatar
If you want 325whp, then skip the sleeves and rods, just use ARP Rod Bolts and stick the money on a quality set of rims and tires, upgraded cooling system, brakes, tuned suspension and a decent radio...
Old Apr 6, 2004 | 02:08 PM
JDcompman's Avatar
Default Re: final build plan (Sunrise City Rider)
I've only heard of a couple of people that have had the ACL's fail. I agree most of it is hearsay. Lots of products get one bad experience out on the internet and everyone assumes their products are junk. I try to not jump on that bandwagon, but I'm sure both should work out fine for you as long as everything is assembled correctly. I was just pointing out something I've heard, not trying to be critical but I too agree that most failures are from improper assembly and not bad products.
Alex Safford
Engine Management and Tuning
Feb 24, 2019 04:30 AM
butt17
Sep 22, 2014 04:25 PM
black_ek
Mar 9, 2007 10:04 AM
Roky
Nov 15, 2003 07:12 PM
