Code 13
Old Mar 31, 2004 | 10:27 AM
ExVtec's Avatar
Default Code 13
Well I am happily boosted. I am running the hack, great except for throwing a check engine light.
Code 13 - BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor.
Not quite sure whats up with that? IS it normal, can I do something to fix this. Any help or ideas welcome.
Thanks all in advance.
Old Mar 31, 2004 | 02:36 PM
ExVtec's Avatar
Default Re: Code 13 (ExVtec)
Bump for an answer...
Old Mar 31, 2004 | 03:13 PM
FredoSP's Avatar
I got that code with the Greddy Blue box, I dont think it affected me.
Old Mar 31, 2004 | 03:15 PM
G
sh!t happens.
Default Re: Code 13 (FredoSP)
whats your set up?
Old Mar 31, 2004 | 03:26 PM
havok hybrid's Avatar
Default Re: Code 13 (G"UNIT)
the BARO sensor is in the car.. on the passanger side... in the area where a obd 1 ecu goes.. in that kick panel...
there is a black sensor in there..
never had that code... just know what is it ..
Old Mar 31, 2004 | 03:39 PM
DC2R714's Avatar
Default Re: Code 13 (havok hybrid)
Unfortunately it is a common code thrown by hack users. Some get it, some don't. Won't effect how the car drives.
Old Mar 31, 2004 | 03:55 PM
ExVtec's Avatar
ok, it doesn't seem to have affected drivability. M question is how can I make it stop..lol. Any clue..
Thanks all....
Old Mar 31, 2004 | 03:57 PM
pip9's Avatar
pull the cel bulb
Old Mar 31, 2004 | 05:37 PM
ExVtec's Avatar
Default Re: Code 13 (pip9)
hmm...no. Is it something I have to live with or just keep resetting my Ecu everyday...
Old Apr 1, 2004 | 05:34 AM
EE_Chris's Avatar
The MAP and Baro are similar sensors. With a key-on, engine-off condition, they should spit out the same voltage. The ECU, during the time you go to start your car, looks at these values and compares them. The VAFC has already changed the MAP sensor output voltage before you ever turned the car on....hence the code.
Old Apr 1, 2004 | 11:02 PM
d16tuner's Avatar
Default Re: Code 13 (DC2R714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">Unfortunately it is a common code thrown by hack users. Some get it, some don't. Won't effect how the car drives.</TD></TR></TABLE>
nothing you can do but ignore it. Just check every once in awhile to make sure you aren't throwing any additional codes.
kizner
Jan 29, 2006 09:39 AM
RRRex
May 7, 2003 05:06 PM
UNDER PRESSURE
Feb 4, 2003 01:07 PM
White Lightnin
Jun 28, 2002 09:15 AM
