secondary O2 sensor eliminator for obd2?
Old Apr 4, 2004 | 07:54 AM
highboostb18c1's Avatar
Default secondary O2 sensor eliminator for obd2?
has anyone evr heard of wrapping the second o2 sensor with aluminum foil to eliminate using the o2 sensor in the down pipe, i only have a test pipe so the 2nd o2 will throw a check engine. Someone said wrap the 2nd o2 real tight with aluminum foil. i'm about to try it but has anyone ever heard this?
Old Apr 4, 2004 | 08:08 AM
HXMan's Avatar
Default Re: secondary O2 sensor eliminator for obd2? (highboostb18c1)
I had mine wrapped in aluminum foil and it worked fine. no CELs.
Old Apr 4, 2004 | 10:50 AM
fbp-em1's Avatar
Default Re: secondary O2 sensor eliminator for obd2? (HXMan)
i tried the aluminum foil and it work for about 2 weeks then i got a cel..you can get o2 simulators pretty cheap
ncpk1234
Mar 18, 2009 06:40 PM
Frstyl838
Mar 2, 2009 03:30 PM
SpoonEk253
Mar 22, 2006 06:10 PM
eLeCtRoNSi00
Mar 1, 2005 07:25 AM
john d
Nov 15, 2004 01:11 PM
