Overheating question
Old Jul 24, 2004 | 06:47 PM
erikiksaz1's Avatar
Default Overheating question
I eas wondering if any of you can help me figure this out. I was wondering if I have a blown headhgasket. I have a 00 Si boosting 7 psi, no oil in radiator, fans kick on, resevoir tank is always in the same level (never overflows), no oil in the radiator. Only time it starts overheating is when it gets 90 plus degrees outside. On a decently warm day, I can turn on the AC, no overheating whatsoever. It seems to just like to overheat in the summer. Just recently changed the coolant and the thermostat. Any ideas?
Old Jul 24, 2004 | 07:39 PM
Haberdasher's Avatar
Default Re: Overheating question (erikiksaz1)
Do you have a water temp gauge? What does it read?
Unless you live somewhere where you get freezing temps you don't need to run antifreeze. Distilled water with some water wetter is the way to go
Old Jul 24, 2004 | 07:45 PM
Jared's Avatar
Default Re: Overheating question (Haberdasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haberdasher &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a water temp gauge? What does it read?
Unless you live somewhere where you get freezing temps you don't need to run antifreeze. Distilled water with some water wetter is the way to go </TD></TR></TABLE>
yes you do. antifreeze isn't just a non freezing agent. it also lowers the boiling point of the water and provides corrosion protection against rust that straight water causes. a 50% mix of water/antifreeze is best and then add a little water wetter.
Old Jul 24, 2004 | 08:16 PM
TurboRedSi's Avatar
Default Re: Overheating question (Jared)
In my turbo setup mentioned above in the 1st post, I'm using 50-50 water/antifreeze.
Old Jul 24, 2004 | 08:28 PM
TurboRedSi's Avatar
Default Re: Overheating question (TurboRedSi)
forgot to mention, no water temp gauge. My stock gauge usually when the car gets hot only goes up 3/4 of the way. Need more input please.
Old Jul 25, 2004 | 07:50 AM
TurboRedSi's Avatar
bump
Old Jul 25, 2004 | 09:05 AM
vtekstorm's Avatar
i would change the radiatior put in a bigger one cuz there is alot of heat build up under that hood now. or u can try this stuff called 40 below. it helps the engine run cooler. i found it at a performance shop. they use it for muscle cars it worked so try giving it a shot. but for my 99 ex i put in a fluidyne in mines and it dnt over heat nomore. honda sells premixxed antifreeze 50/50
Old Jul 25, 2004 | 10:29 PM
TurboRedSi's Avatar
Default Re: Overheating question (vtekstorm)
thnaks, I was thinking it might be the radiator not being sufficient enough. Anyone else?
Old Jul 26, 2004 | 06:24 AM
mike1114's Avatar
you said you just replaced thermostat and fluid, might you have bubbles in you lines because you didn't bleed enough? Air pockets will cause the fluid not to flow through the system.
Old Jul 26, 2004 | 09:47 AM
u2civic1's Avatar
Default Re: Overheating question (mike1114)
i had the same problems until i switch over to a dual core one
Old Jul 26, 2004 | 01:27 PM
pa2play's Avatar
Default Re: Overheating question (u2civic1)
i had some overheating problems a few weeks ago and took it to a radiator shop and he showed me that my radiator was falling apart. Take a look at yours and see if you fins are falling out or if your radiator is all green, if so, my might need a new one.
Old Jul 26, 2004 | 01:30 PM
TurboRedSi's Avatar
I just find it strange and a waste having to yank out the old radiator with no leaks. It worked fine all motor, and I barely boost driving daily. What about adding a pusher fan in fronmt of the radiator to get more air through? What do you think about that idea?
Old Jul 26, 2004 | 01:58 PM
vtekstorm's Avatar
change the radiator. put a bigger one in u cant go wrong wit it. it will work much better than the stock one.
hatchman88
May 30, 2009 05:50 PM
project civic
Mar 16, 2006 09:46 AM
toohott4handlin
21
Feb 8, 2004 03:47 AM
Bobby-SiR
16
Jun 19, 2003 06:30 PM
Albino Dragon
Apr 18, 2002 10:15 PM
