turbo exaust outlet
Old Jul 20, 2004 | 07:35 PM
projectPSI's Avatar
Default turbo exhaust outlet
I got a little problem with my exhaust outlet. I broke off one of my bolts and i cant get it out of the turbo. Will the exhaust hold fine if I just use 3 of the 4 bolts? Should I use jb weld to help hold it in?
Old Jul 20, 2004 | 08:10 PM
Charlie Moua's Avatar
Default Re: turbo exhaust outlet (thundergrayteg)
try it
with just 3 bolts.
then use some c-foam to see if you have a exhaust leak..
i'm thinking it work work...
Old Jul 20, 2004 | 08:12 PM
RyanEJ8's Avatar
Try using some high temp RTV gasket too in case there is a small gap where there isn't a bolt.
What kind of bolts were you using? Use stronger ones next time.
Old Jul 20, 2004 | 08:32 PM
gritsak's Avatar
Default Re: turbo exhaust outlet (RyanCivic2000)
have you tried using an extractor bit to get the broken bolt out?
Old Jul 21, 2004 | 06:19 AM
projectPSI's Avatar
There was studs in the turbo that I was trying to take out. Apperantly one was in there too tight and i snaped it. I did try a screw extractor but i just broke that in there. Thanx for the help.
Old Jul 21, 2004 | 06:28 AM
DaX's Avatar
DaX
Loved
Community Favorite
Grind and drill until that thing is out. Never give up and resort to a bandaid fix.
Old Jul 21, 2004 | 07:51 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
3 bolts will probably leak, and you can't use JB weld or RTV because the temps are too high. Just drill it, tap it, and be done with it. Fix it right the first time instead of wasting way more time on some ghetto fix.
Old Jul 21, 2004 | 07:57 AM
PM-Performance's Avatar
Default Re: turbo exhaust outlet (tjbizzo)
JB weld deff wont hold. RTV might, but its chancy. keep trying at getting the bolt out. worse to worse take it to a machine shop.
teknikEG6
Oct 2, 2005 12:14 PM
u2civic1
Apr 14, 2004 06:28 PM
_Endless_
Jun 9, 2003 06:58 AM
B18C-RnVA
Sep 15, 2002 06:59 PM
CovertFI
Aug 26, 2002 04:15 PM
