This is a bit off topic guys but maybe you could help me out ... (240sx Related)
Guest
Posts: n/a
Well I bought a 240sx recentley . A black 240 fastback with 100K Something miles on it . But with 900 dollars there comes some problems. I was thinking of going with a SR20 swap but I found a cheaper swap (ca18det) . Im going to go with that one . Before I go turbo I need to fix these problems. The biggest problem I need help with is in BOLD. So please help me out. passenger side window stuck. (f*ck my passengers)
windshield cracked. (its a small small crack)
occasionally needs power steering fluid.
rear chatter on power on right turns. ( this is the thing that scares me. The car shakes at hard right turns when I put the pedal to floor. The back right tire sounds like its skipping. ANy help on this would be greatley appreciated.
don't know where the key is for the bike rack. (it was already on there)
NEEDS SHOCK! (got teins on the way)
check engine light occassionally comes on. (problably misfire)
passes smog ok. (good thing)
odometer stopped at 106k mi (im guessing this is a odometer problem since the speedometer and rpm work)
Thanks alot guys can you guys help me on my problems
Re: This is a bit off topic guys but maybe you could help me out ... (Rocks)
1. get a new one.
2. find leak and fix the problem.
3. probably just a wheel bearing or shity tires/bent wheel.
4. rip it off
5. ....okay
6. check the codes and fix it.
7. ....right
8. if the spedo works and the odometer doesnt then you need a new cluster.
Landon
4. rip it off
5. ....okay
7. ....right
Landon
civicsedan89
15
12-13-2010 12:27 PM
