Warm Starting With The HACK????
Old Jul 23, 2004 | 10:38 PM
impound's Avatar
Default Warm Starting With The HACK????
i read there was a trick to it so it will start right up....what is it????if you tell me to search......go look thru the 258 posts...also whats a good fuel pressure setting ????
i'm set at 52psi with vacuum hose off...thanks in advance
-b16
-drag3 kit
-walbro 255
-vafc
-b&m fpr
dsm 450s
Old Jul 23, 2004 | 10:41 PM
b16hybridsol's Avatar
Default Re: Warm Starting With The HACK???? (impound)
i was runnin 40psi when i had the hack and it'd fire right up, warm or cold this was on an h22 tho
Old Jul 24, 2004 | 04:55 AM
impound's Avatar
Default Re: Warm Starting With The HACK???? (b16hybridsol)
i was reading something on it in my afc hack search but after trying to find it again last night.......it just seems like there is no gas in it...takes a couple of times for it to fire
Old Jul 24, 2004 | 11:08 AM
did you do the endyn mod to the b&m fpr, cause that will cause this
Old Jul 24, 2004 | 01:26 PM
impound's Avatar
what is the endyn mod?????
Old Jul 24, 2004 | 04:01 PM
drill a very small hole in the inside of the fpr. if you don't know what it is you prly don't have it done, so never mind on that
Old Jul 24, 2004 | 06:00 PM
impound's Avatar
yeah dont have that one done...
Old Jul 24, 2004 | 09:00 PM
Iceman05's Avatar
all hack users have a hard time warm starting w/450s. just give it a lil gas, thats all u can do...
Old Jul 25, 2004 | 08:17 AM
impound's Avatar
Default Re: (Iceman05)
thanks for replies....do i need to let the pupmp prime then give it a lil gas then start?
billk2k
Jun 13, 2005 08:18 PM
89 CRX SI
Feb 3, 2004 06:01 PM
redhatchb18
Oct 21, 2003 11:43 AM
Hoodwinked
Sep 3, 2003 08:30 PM
NeXtLeVeL_TyPe_R
Jul 26, 2003 11:58 PM
