fluctuating boost gauge..
Old Jul 24, 2004 | 06:27 PM
S2KP's Avatar
Default fluctuating boost gauge..
I have an Autometer Ultra lite boost guage and before it would hit 15psi, it would flutuate. Like the needle would shake between 14-16psi. Im running a Turbo XS high performance boost controller and the boost guage is hooked up to a Golden eagle vacuum block.....Anyone had this problem?
Old Jul 24, 2004 | 06:38 PM
Bailhatch's Avatar
Default Re: fluctuating boost gauge.. (Turbo_Siii)
i have seen it on other gauges that don't have an inline restrictor. They would tend to flutter up to full boost then hold there. maybe you just need to make a little 'pill' with a tiny hole drilled in it to smooth it out. I would just run it if that is really what the boost pressure is doing.
I think the fitting on the back of an autometer gauge already has a small hole. i don't know i guess. does it bother you?
kcjohnnyboy
Dec 1, 2003 02:38 PM
turbonitrousgsr
Oct 6, 2003 06:54 AM
cajnatc
Jun 13, 2003 04:18 AM
CRVRX
Nov 16, 2002 08:03 PM
Aeka GSR
Mar 26, 2002 02:12 PM
