Greddy kit (internal wastegate) + b18c5 = overboost :(
Hey all,
Well my tuner finally got everything together and put my car on the dyno... stock b18c5, greddy turbo kit, greddy intercooler, e-manage, profec B spec II. Stock greddy downpipe, test pipe, and Tanabe Racing Medallion exhaust. I still have the stupid intake restrictor plate on the intake (comes on the b18c kits from Greddy).
Anyhow- it hits 9 psi at 5800 RPM and won't go any lower, even disconnecting the profec B and loosening the spring on the internal wastegate. Didn't take it past that.
So, looks like I need an external wastegate. I was looking forward to the quieter internal wastegate.
Anyone surprised? Any suggestions?
-Chris
-Chris
Re: Greddy kit (internal wastegate) + b18c5 = overboost :( (ccfries)
you might try changing vacuum sources to the wastegate. See if that makes it open sooner.
Try the braker booster line.
Re: Greddy kit (Black Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Si »</TD></TR><TR><TD CLASS="quote">just tune it to 9psi</TD></TR></TABLE>
It looks like it'll go past 9 PSI if I took it any higher (which I didn't want to, not with a stock ITR motor).
I'll try changing the vacuum source and lengthening the actuator arm a bit. Otherwise I'm off to get an external wastegate.
Hopefully I'll get it running stable before a HPDE in a week (Blackhawk farms in Rockton IL)
I'm open for more ideas Thanks for the quick posts guys.
