missing link noise?
Old Jul 20, 2004 | 05:38 PM
XBoostedAccordX's Avatar
Default missing link noise?
i just installed an OBX map sensor adapter, and when i started my car it makes a hissing noise. i believe its out that little hole on the side of it? is this normal or did i install it wrong? thanks for any help
Old Jul 21, 2004 | 03:20 AM
Default Re: missing link noise? (XBoostedAccordX)
bump
Old Jul 21, 2004 | 04:54 AM
Firewerks's Avatar
Hissing noise??? i`ll assume that this is at an idle. a missing link should only be venting when there is pressure. I.E. under boost. most commonly used to stop the map sensor from seeing positive air pressure and going bonkers.
If it is venting all the time and was installed right side up, the missing link needs to be replaced. if not, i would recommend double checking the direction of the piece. being a check valve there is an up and a down.
hope that helped
Old Jul 21, 2004 | 03:01 PM
Default Re: missing link noise? (Firewerks)
Thanks firewerks for the reply.
The small hole goes on top right and the larger hole on the bottom when mounted right?
nicktagz
Sep 8, 2006 11:01 AM
sol-fire
Aug 25, 2004 09:40 PM
Integra_Boi
Oct 22, 2003 07:55 AM
Synapse
Feb 18, 2002 08:24 AM
FBP Si 2000
Oct 2, 2001 08:09 AM
