Supercharger Problem need help.... FAST
Old Jul 21, 2004 | 10:21 AM
FOrSfEd's Avatar
Default Supercharger Problem need help.... FAST
My friend has a jackson racing superchager on his b16. For some odd reason when he turns the car on the motor revs up and dosen't stop, so we have to turn the car off to keep from the motor blowing. If we disconnect the throttle cable is does the same thing. Anyone ever have this problem or no how we can fix it.
Old Jul 21, 2004 | 10:28 AM
RacerXI's Avatar
Default Re: Supercharger Problem need help.... FAST (FOrSfEd)
Vacuum leak..check nuts from manifold to blower. It's definitely a vacuum leak though.
Old Jul 21, 2004 | 10:36 AM
FOrSfEd's Avatar
Default Re: Supercharger Problem need help.... FAST (RacerXI)
OK thanks I will def check that. Anymore thoughts
Old Jul 21, 2004 | 10:43 AM
RacerXI's Avatar
I had a jrsc b16 and it did the same thing. It would rev straight to 6500 and hold it right after you fired the car up. We chased it down to being loose bolts holding the blower section to the manifold. Don't fret though as it's happened before.
Old Jul 21, 2004 | 11:29 AM
Rory Breaker's Avatar
Huge vacuum leak. Blower/manifold is a good first place to check.
Old Jul 21, 2004 | 11:39 AM
FOrSfEd's Avatar
Default Re: Supercharger Problem need help.... FAST (newgsrdriver)
thanks alot fellas.
Old Jul 22, 2004 | 11:07 AM
turboda6's Avatar
check tps. my sock ls did that once... i put a new t/b on and when i started it it went straight to 4500 rpm then i tapped the gas peddle and it went up to 7k and stayed there. just a thought.
Skunk2DC2
Aug 11, 2012 12:30 PM
TopGear_
Aug 18, 2009 11:15 AM
cyberx
15
Feb 11, 2004 09:00 PM
DeDonDeRosa
Dec 22, 2002 06:14 AM
blkrice
Oct 9, 2002 03:24 PM
