SOHC custom set up.... ur thoughts?
Old Jul 22, 2004 | 06:13 PM
StockCivicRacer's Avatar
Default SOHC custom set up.... ur thoughts?
Like the topic says.... im piecing together a kit myself and so far this is what i have come up with.....
Spoolin Performance manifold, IC piping and DP
Tyrus intercooler
blitz BOV
tial WG
fast turbo oil return/feed lines
MBC.... not sure which one
garrett t3/to4e 50 trim .48 ar
hondata s200
conversion harness and chipped ecu i would need
rc 550 injectors
walboro 255 fuel pump
does this seem like it would be an alright kit? if not then anyone got any reccomendations? i would like to put down over 200 whp with the initial set up, and build from there. your opinions are MORE than wanted.... thanks
Old Jul 22, 2004 | 06:18 PM
MyWhiteCivic's Avatar
Default Re: SOHC custom set up.... ur thoughts? (StockCivicRacer)
If your in the market for a boost controller, I have a TurboXS Dual Stage MBC that I am most likely getting rid of.
Old Jul 22, 2004 | 06:22 PM
drvfast's Avatar
Sounds like a good start.
Old Jul 22, 2004 | 06:33 PM
Default Re: SOHC custom set up.... ur thoughts? (drvfast)
Thanks.... anyone else got any feedback? perhaps sugguestions?
Old Jul 22, 2004 | 07:08 PM
civicspeed's Avatar
What size of dp and exhaust are you gonna run?
Old Jul 23, 2004 | 07:56 AM
Default Re: SOHC custom set up.... ur thoughts? (civicspeed)
i was gonna go 2.5" because i want to keep it a/c compatable. Anyone else got any thoughts? And advise? thanks.
Old Jul 23, 2004 | 08:31 AM
anyone?
Old Jul 23, 2004 | 01:25 PM
RyanEJ8's Avatar
I'd flare the downpipe to 3" after the A/C compressor and go with a 3" exhaust. Sounds like a good setup to me. Good choice of turbo.
Old Jul 23, 2004 | 11:02 PM
Default Re: SOHC custom set up.... ur thoughts? (RyanCivic2000)
Thanks for the feedback. Anyone else? All help and ideas are appreciated.
Old Jul 24, 2004 | 07:46 AM
blackeg's Avatar
very solid for a first setup
Old Jul 24, 2004 | 08:08 AM
Default Re: SOHC custom set up.... ur thoughts? (blackeg)
Thanks again. Starting to make me feel better about the choices i have made. Now.... about flaring the DP to 3"...... how much of a difference do you all think it would make? Just wondering..... i hadnt thought about doing that. Thanks again for the feedback, and keep it coming.
Old Jul 24, 2004 | 10:06 AM
T-RO's Avatar
I've got resistor boxes for sale. lol
Old Jul 25, 2004 | 10:58 AM
anyone else?
Old Jul 29, 2004 | 12:17 PM
is there anything that im missing that i will need for this set up? just want to make sure thats all. thanks for the help.
Old Jul 29, 2004 | 12:21 PM
fjt's Avatar
fjt
Dont you need a GM 3 bar map sensor for Hondata? What about a Wideband O2?
Old Jul 29, 2004 | 12:31 PM
Default Re: SOHC custom set up.... ur thoughts? (fjt)
hmmm.... im not sure.... thats y im asking.... why exactly would i need those? and what do they do? thanks again.
Old Jul 29, 2004 | 12:40 PM
fjt's Avatar
fjt
Well i dunno if the Hondata comes with a map sensor but if not you will need a better than your OEM one if you plan on going more than 11PSI+/-..after that your Honda Map sensor craps on you and turns on the CEL..
The wideband is for dataloging in the Hodata i think and also to read/tune your Air Fuel Mixture which is critical in a turbo setup...This is mostly used for street tunning.
Old Jul 29, 2004 | 12:42 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">Dont you need a GM 3 bar map sensor for Hondata? What about a Wideband O2?</TD></TR></TABLE>
The 3 bar is not a requirement but the stock map will only read to 11psi.
I fyou are tuning the car, a wideband is a must.
Old Jul 29, 2004 | 12:44 PM
Honda_Tengoku's Avatar
looks allright to me. If u have a stock bottom end D16 the 550 CC injectors are a bit over kill. The 450 CC's are a bit better for your application IMO.
Old Jul 29, 2004 | 05:09 PM
Default Re: SOHC custom set up.... ur thoughts? (Honda_Tengoku)
If i do need the wideband deal..... then where do i go about getting it? Thanks.
The Mista Mike
Mar 26, 2006 07:28 AM
njfinest05
Nov 29, 2005 12:19 PM
lukebohn
Oct 5, 2005 08:01 AM
stock00civic
May 5, 2005 08:17 AM
Vp Special K
Apr 23, 2005 08:28 PM
