HOW MUCH NITROUS CAN I RUN
Old Jul 25, 2004 | 10:01 AM
evilk's Avatar
Default HOW MUCH NITROUS CAN I RUN
HOW MUCH NITROUS(DIRECTPORT) CAN I RUN IN MY LS/VTEC MILD BUILD NEW VALVE DUAL SPRINGS RETAINER EAGLE RODS AND JE PISTON..SO HOW MUCH NITROUS YA THINK I CAN RUN............................................... .................
http://WWW.TEAMKINETIC.COM
Old Jul 25, 2004 | 10:08 AM
wolfsburg2's Avatar
Default Re: HOW MUCH NITROUS CAN I RUN (evilk)
WITH A PROGRESSIVE CONTROLLER AND ENOUGH FUEL I WOULD THINK A 150 SHOT WOULD BE POSSIBLE
Old Jul 25, 2004 | 10:10 AM
evilk's Avatar
Default Re: HOW MUCH NITROUS CAN I RUN (wolfsburg2)
U THINK SO SUM PEOPLE SAY THAT MY BLOCK WOULDN HANDLE IT EVEN WIT A BLOCK GUARD
Old Jul 25, 2004 | 10:24 AM
m R g S r's Avatar
yea it will. you need some good tuning thou...
Old Jul 25, 2004 | 10:44 AM
Airman45's Avatar
From: On the Moon with 5 beautiful ladies, Ont., Canada
Default Re: HOW MUCH NITROUS CAN I RUN (m R g S r)
NAWWWWWS y0 g1V35 y4 p0w4R w00T!
Old Jul 25, 2004 | 11:36 AM
Cord 2oo1's Avatar
Default Re: HOW MUCH NITROUS CAN I RUN (Airman45)
Just to let you know block guards are not very safe for ur engine, there was someone on this board a couple years ago whose engine caught on fire because he was sprayin and had a block guard, i believe they raise the temperature of ur engine alot.
Tom
Old Jul 25, 2004 | 05:11 PM
evilk's Avatar
Default Re: HOW MUCH NITROUS CAN I RUN (Cord 2oo1)
damm i never heard of that **** b4 i spray all tha time but wit a zex kit 75 ..but now i want a nos direct port system
Old Jul 26, 2004 | 10:07 PM
rev-speed's Avatar
i spray 125 with the plate kit at 11-1 air/fuel
stock gsr
and we have a d16y5 whick is a hx motor on the 12 bottle with a single nozzle 80 wet
Old Jul 28, 2004 | 05:09 AM
evilk's Avatar
Default Re: (4cylinder)
damm cuzz thats a lot of nitrous on a stock gsr
Old Jul 28, 2004 | 05:27 AM
h22turbolude's Avatar
I heard you can safely put a shot the size of half of your horsepower to the wheels.
Old Jul 28, 2004 | 07:42 AM
swift535's Avatar
on a single nozzle (wet kits at least) you can do an extra 20hp per cylinder without having to worry, as long as you use premium gas too (93oct)
Old Jul 28, 2004 | 02:08 PM
whatVTEC's Avatar
I'm running 150shot on my LS, almost same mods. It's not tuned, so I dunno how safe it is, but I haven't had any problems yet and it's been 2yrs.
Old Jul 29, 2004 | 03:06 PM
evilk's Avatar
Default Re: HOW MUCH NITROUS CAN I RUN (whatVTEC)
150 shot on a ls motor i think thats too much
Old Jul 29, 2004 | 03:33 PM
TEZTnTUNE's Avatar
100 to 125 shot is not bad. u should be prepared for it tho. some colder plugs, a large plenum intake manifold, good free flowing headers, and a 2.5 inch exhaust will be good. oh and most importantly some kind of ignition tuning wouldnt hurt. msd btm at least or uberdata. i believe there is nitrous control for it out but dont quote me tho not 100% good luck
Old Jul 29, 2004 | 05:25 PM
whatVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evilk &raquo;</TD></TR><TR><TD CLASS="quote">150 shot on a ls motor i think thats too much</TD></TR></TABLE>
does it matter what motor it is?
would it be ok if it was B16 or gsr?
Old Jul 29, 2004 | 05:48 PM
TEZTnTUNE's Avatar
hey if its good enough for the red baron its good enough for an ls
Old Jul 29, 2004 | 05:57 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
would it be ok if it was B16 or gsr? </TD></TR></TABLE>
mainly on compression ratio i would think... higher compression ratio would be more prone to detonation under a higher shot of nitrous then a lower compression ratio
Old Jul 29, 2004 | 07:06 PM
evilk's Avatar
yea i guess it would be ok to run it like that
jdmeg94hatch
Sep 24, 2006 02:15 AM
jdmeg94hatch
13
Aug 9, 2006 10:30 PM
lsvtec94
Aug 9, 2002 12:30 PM
blackac
Dec 6, 2001 06:31 AM
