Victor X throttle body placement?
I currently have a stock GSR intake manifold and will be switching to the Edelbrock victor x. Id like to know if anyone has had experience with the charge pipe not fiting the throttle body..
Does the manifold change the throttle body position? short runners? different hieght? Thanks for any input as always guys...
Re: Victor X throttle body placement? (D@nnY)
the TB will be a few inches higher, you charge pipes should still fit, it isn't much of a difference. My cold air intake still fit when i switched manifolds.
sounds about right..im wondering if it will also move closer to the head because of the shorter runners...the gsr charge pipe dips down very low...
slide inside
10-21-2009 01:15 AM
949
12-03-2008 03:06 PM
Getting a bigger throttle body does that requir getting a bigger intake pipe to fit around the throt
DroppedTegra
01-16-2002 06:58 AM
