Transmission Techs
Old Jul 22, 2004 | 06:14 PM
ntegls's Avatar
Default Transmission Techs
Just wondering because my tranny is messed up for now, but what would cause the teeths on my differential ring gear and the part on the counter shaft that it rides on break???
96 ls with 107,000k drag kit boosting 6.5psi since 102,500, using honda mtf, clutch master stage 3 since 60,000k. I really dont beat it too much.
Could mis-shifts/hard downshifts caused this, excessive heat causing gears to weaken. I need to know what I can do to prevent this in the future after the transmission rebuild.
Old Jul 22, 2004 | 06:16 PM
ntegls's Avatar
I'm thinking it may be excessive heat. After driving around in traffic and this hot weather/turbo heat my transmission starts to act funny. I dont have any problems shifting into gears, other internal parts looks normay for a transmission w/ 107,000k on it.
Old Jul 22, 2004 | 06:38 PM
Jared's Avatar
Default Re: Transmission Techs (ntegls)
I've never seen broken teeth on ring and pinion gears to break, except in cases of lots of power and/or big slicks.
Jared's Avatar
btw, if it becomes hard to shift after hot, its probably not the trans, most likely you have slave cylinder going bad.
Old Jul 22, 2004 | 07:09 PM
ntegls's Avatar
Do you think 205whp and 195ft/lbs a lot of power at 6.5psi, I see other guys around here hitting a lot more to the wheels and no tranny problems
Old Jul 22, 2004 | 07:37 PM
DaX's Avatar
DaX
Loved
Community Favorite
Have you been launching? It's all in the launch...
Old Jul 23, 2004 | 06:54 PM
ntegls's Avatar
Since its been turbo charged I've only street raced about 8 total times/launches. When the tranny started to go I didnt really beat on the tranny, just normal driving boosting high every once in a while to past cars.
Could of been caused when I let my friends use it to go to the store.
I think that may be the culprit but I cant say for sure.
Old Jul 24, 2004 | 06:49 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (ntegls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntegls &raquo;</TD></TR><TR><TD CLASS="quote">Could of been caused when I let my friends use it to go to the store.
I think that may be the culprit but I cant say for sure.</TD></TR></TABLE>
More than likely the culprit. Your best friends are the worst people to let drive your car.
mr_munro
Transmission & Drivetrain
13
Dec 29, 2010 11:08 PM
alaskanlue
Jul 20, 2009 09:30 PM
b20vtech
13
Sep 23, 2008 01:46 PM
3.point.2
14
Apr 13, 2006 10:46 AM
94Vtecluder
May 28, 2004 05:43 AM
