Need help fast. Idle problem.
Old Jul 22, 2004 | 09:15 PM
SpdFrk's Avatar
Default Need help fast. Idle problem.
Okay today my car was running fine and everything until i tried to setup my AVCR according to this site http://www.boosted-hybrid.com/viewtopic.php?t=806. I had it setup according to APEXI's instruction but i always had overboosting problems. Anyway, when i set it up according to boosted-hybrid's site my car idled REALLY bad. So i decided to change it to the way i had i to apexi instructions. When i changed everything back to normal and i tried to start my car it would idle at 2000rpms and it would keep rising 100rpms a second. I disconnect the valve solenoid and the im running off the waste and i still have the same problem. What could be the problem???
Heres my setup:
00 Si B16a2
siemens 903cc injectors
aeromotive FPR
AEM EMS
Lovefab sst
turbonetics t3/t4b
tial 35mm w/5.5psi spring
Old Jul 22, 2004 | 09:23 PM
Adriano's Avatar
Default Re: Need help fast. Idle problem. (SpdFrk)
check for vacuum leaks.
Old Jul 22, 2004 | 09:32 PM
SpdFrk's Avatar
Default Re: Need help fast. Idle problem. (brryder)
I checked for that and there was none. Everthing connected on the manifold is tight.
Si[R]'s Avatar
could it have anything to do with the AEM EMS???
Old Jul 22, 2004 | 09:44 PM
SpdFrk's Avatar
Default Re: Need help fast. Idle problem. (Si[R])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si[R &raquo;</TD></TR><TR><TD CLASS="quote">]could it have anything to do with the AEM EMS???</TD></TR></TABLE>
Good question. Anybody?
Old Jul 23, 2004 | 08:10 AM
SpdFrk's Avatar
somebody please help.
Old Jul 23, 2004 | 10:13 AM
SpdFrk's Avatar
no 1 else?
Old Jul 23, 2004 | 10:42 AM
underpressure02's Avatar
I don't see why your avc-r would have anything to do with your idle. All it does is control your boost.
I have avc-r and ems and never have problems and I am always playing with my avc-r. You sure you did not make any other changes? Maybe changed a value in the ems?
Sorry just read BH thread. You only use two ports on your wastegate accuator for the avc-r com and NO if you are using an external wastegate.
Old Jul 23, 2004 | 10:52 AM
Si[R]'s Avatar
Default Re: Need help fast. Idle problem. (underpressure02)
then it must be a vacuum leak.
Old Jul 23, 2004 | 10:53 AM
SpdFrk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si[R &raquo;</TD></TR><TR><TD CLASS="quote">]then it must be a vacuum leak.</TD></TR></TABLE>
You know what. It was i vacuum leak. I rechecked every single line and i saw a vacuum leak.
homeskillet
Jan 13, 2005 05:04 PM
E Swift
Feb 11, 2004 05:33 PM
oemDC2
Feb 3, 2004 08:04 PM
