JRSC install problems
Old Jul 21, 2004 | 02:23 PM
aka Paco's Avatar
Default JRSC install problems
I just installed a JRSC on a b16a and everytime we start the car up it just revs real high... first guess was a vacum leak between the manifold and the charger, but we rechecked everything several times checked it over and over, i don't see how it could be leaking from there... the throttle body isn't opening, the car is just reving hight when we start it..
any help would be appreciated, went over the directions several times as well, the kit was bought used from someone. it worked fine before i got it...
thanks
Old Jul 21, 2004 | 03:40 PM
showtymers619's Avatar
* B A N N E D *
Default Re: JRSC install problems (Lowskee)
sounds like a vacuum leak.. get some carb cleaner and start spraying around the seems of the blower and T/b ... if it bogs theres your problems..
Old Jul 21, 2004 | 10:26 PM
91civicEX's Avatar
check ur pcv vacuum lines
Old Jul 21, 2004 | 10:34 PM
greekspeed's Avatar
Default Re: JRSC install problems (91civicLX)
this exact problem happend to me when i installed my jrsc back in the day... it turned out to be a leak between the head and the intake manifold.
is the intake manifold originally suppose to fit on a b16 head.. or did u have it modified to fit on the head?
Lord Orange
Dec 18, 2018 09:20 AM
supercharged d
Oct 6, 2009 09:04 PM
jdmintegra18
Mar 16, 2009 08:17 PM
Ultraman
Jan 31, 2007 08:38 AM
DeDonDeRosa
Dec 22, 2002 06:14 AM
