D series turbo.
Old Mar 16, 2007 | 10:17 AM
JDM_Frijoles's Avatar
Default D series turbo.
Beware: I'm a n00b. I just bought a DSM TD05H turbo for my D15B. I have an HF manifold, DSM 450's, and a resistor box from a DA(actually the whole harness). Am I headed towards the right direction so far, or do i need a different resistor box?
On a side note, I'm currently searching for a Y8 IM, GSR TB, boost guage, and AFC. Does it matter what BOV i use, because I don't want that loud *** hiss and I dont live in a good area............... I'd like to keep my **** for a while. What size of charge pipes should i use? How big ofa IC do i need for this turbo/setup? BTW my block has stock everything. Plans are ZC slugs and LS rods but another H-T member said to use TunerToyz rods and pistons, is this a good brand?
Also, Can i have pics of peoples downpipes, and adapter plates for this setup. Thanks
Old Mar 16, 2007 | 10:28 AM
slodel's Avatar
Default Re: D series turbo. (JDM_Frijoles)
https://honda-tech.com/zerothread?id=1643764
Old Mar 16, 2007 | 10:43 AM
bump for pics, and links to tunertoyz and silly SOHC, never heard of these guys.
Modified by JDM_Frijoles at 1:56 PM 3/16/2007
Old Mar 16, 2007 | 11:29 AM
civhatch90's Avatar
you seem to be confused, at one place you say your block has stock everything and later you mention different piston/rod set ups. do some more research and come up with a goal hp and more people will be able to help you
Old Mar 16, 2007 | 11:39 AM
slodel's Avatar
i am waiting for tuner toys rods
good place i hear and good cheaper rods
anyway search through that link i gave you there are hundreds of setups
Old Mar 16, 2007 | 11:42 AM
Default Re: (civhatch90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civhatch90 &raquo;</TD></TR><TR><TD CLASS="quote">you seem to be confused, at one place you say your block has stock everything and later you mention different piston/rod set ups. do some more research and come up with a goal hp and more people will be able to help you</TD></TR></TABLE> No, I'm not confused i know my goal, I just want to stiffen up my block inside so i dont blow it in a couple of months. I want to atleast hit 200 whp.
Old Mar 16, 2007 | 11:50 AM
Default Re: D series turbo. (slodel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel &raquo;</TD></TR><TR><TD CLASS="quote">i am waiting for tuner toys rods
Old Mar 16, 2007 | 11:51 AM
oscarmayer's Avatar
stock block can take 200 wheel pwoer, but the D15 rods may be in question.
Old Mar 16, 2007 | 12:32 PM
HiProfile's Avatar
Things required to hit 200whp on a d-series:
*Working stock longblock in good condition
*Turbo & setup components in good condition
*10-15psi on a not-so-big turbo
Anything else will just slightly move the powerband around, but the head and cams are the biggest restriction, with the IM coming in next depending on the engine used. In other words - buy forged pistons/rods & new bearings before any other extras.
LsScivic
May 4, 2008 07:24 PM
JDM_Frijoles
Feb 28, 2007 11:48 AM
rexdout45
Apr 17, 2006 05:10 AM
EJ8 GSR-T
Feb 12, 2006 08:19 AM
