Making t25 fix on d16y8!?!?!?!?
Old Mar 22, 2007 | 04:13 AM
sladed16y8's Avatar
Default Making t25 fix on d16y8!?!?!?!?
hey i have a 97 ex civic and just picked up a t25 off of a saab from a junkyard my question is how do most ppl make them fix because i know most of the turbo manifolds have t3 flanges do you guys go with a adapter plate from a machine shop or wat ive just heard there expensive to be made or i accually found a t2 to t3 adapter flange on ebay but dont know if it would work cuz its from ssautocrome thanks???
Old Mar 22, 2007 | 05:12 AM
aznxmike's Avatar
Default Re: Making t25 fix on d16y8!?!?!?!? (sladed16y8)
i have a t25 manifold for the d16 if you want, never used. selling for 200obo
https://honda-tech.com/zerothread?id=1901794
Old Mar 22, 2007 | 06:56 AM
sladed16y8's Avatar
Default Re: Making t25 fix on d16y8!?!?!?!? (aznxmike)
thats cool if you still have it later ill hit you but does is have a slot for a wastegate on it
Old Mar 22, 2007 | 07:18 AM
bkmc24's Avatar
IM pretty sur t25's have T3 flanges.
and if you got one off a saab, isnt it internally wastgated?
Old Mar 22, 2007 | 07:37 AM
sladed16y8's Avatar
Default Re: Making t25 fix on d16y8!?!?!?!? (bkmc24)
nah its the same rectangle shape but its about a quater to half inch smaller the flange that is and my turbo does have the wastegate but idk wat psi its set at and i might want to change it
Old Mar 22, 2007 | 01:32 PM
aznxmike's Avatar
it doesnt have a spot for a wastegate, only works with internal wastegated turbos.
Old Mar 22, 2007 | 03:25 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bkmc24 &raquo;</TD></TR><TR><TD CLASS="quote">IM pretty sur t25's have T3 flanges.
and if you got one off a saab, isnt it internally wastgated?</TD></TR></TABLE>
T25's will either use a T2 flange, or a gay proprietary flange from the auto mfg.
The way most people get t25's to work is by using an HF manifold + adatper plate, a log/ramhorn manifold with t25 flange, or the hks/greddy manifolds (they use the t25 flange). There simply isn't enough room in a civic's engine bay to use a t3-t25 adapter plate. The only way it would work is with t25 and t3 flanges welded together, studs put in each side, and a manifold that had through-holes in the manifold that you can use nuts with. Usually that means ssautcrome, ramhorn, minime/elf, or a log with the flange extended out a bit. Either unreliable, expensive, or just not easy to find.
Old Mar 26, 2007 | 10:52 PM
bkmc24's Avatar
Default Re: Making t25 fix on d16y8!?!?!?!? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">
The way most people get t25's to work is by using an HF manifold + adatper plate, a log/ramhorn manifold with t25 flange, or the hks/greddy manifolds (they use the t25 flange). There simply isn't enough room in a civic's engine bay to use a t3-t25 adapter plate. The only way it would work is with t25 and t3 flanges welded together, studs put in each side, and a manifold that had through-holes in the manifold that you can use nuts with. Usually that means ssautcrome, ramhorn, minime/elf, or a log with the flange extended out a bit. Either unreliable, expensive, or just not easy to find.</TD></TR></TABLE>
Well im pretty sure the T25 i had off the SR20 from my brothers car had a t3 flange chief
Old Mar 27, 2007 | 09:39 AM
jfruauff's Avatar
some have t3 flanges too. I belive it only the sr and rb motors
4g4dcruisin
Aug 30, 2009 04:30 AM
Justin Olson
Welding / Fabrication
11
Mar 19, 2007 09:52 AM
delslo93
Jan 27, 2005 06:36 PM
boostedblack99
May 27, 2003 08:27 PM
Mr. Softee
Oct 7, 2002 01:46 PM
